Dart 8.1 Gen 7 Iron Heads >
Old 02-28-2012 | 09:15 PM
  #131
crayolacrazy's Avatar
Originally Posted by Rage
Thanks. Did you get the heads flowed before or after adding the bigger intake valve ? Numbers?
What springs did you put in?
What cam are you running?
I went by the no.s on this thread . I was allready running the bigger valve size in my cnc,d heads .I didnt want to go backwards. The lift on my cam is 621,if im not mistaken Ill check the springs are a triple spring from comp.
crayolacrazy is offline
Old 03-01-2012 | 10:22 AM
  #132
Rage's Avatar
Thanks. Let us know the comp spring number when you can.
Any pictures available of the Dart heads in full dress including rockers?
Rage is offline
Old 03-02-2012 | 01:25 PM
  #133
Rage's Avatar
Default Dart Gen7 8.1 Head CFM #'s
Dart just sent me their head flow numbers.
DART 8.1L GEN7 Iron Eagle BBC Flow
Valve 2.190" 1.880"
Lift 320cc Int 128cc Exh
.200 159 131
.300 221 178
.400 271 211
.500 312 237
.600 345 255
4.500 bore
Note: Flow numbers can vary up to 5% in
production castings.
Rage is offline
Old 03-07-2012 | 05:15 PM
  #134
Valve 2.190" 1.880"
.200 159 131
.300 221 178
.400 271 211
.500 312 237
.600 345 255
4.500 bore
how can the boar be that large 4.280 is 30 over.
Old 03-07-2012 | 07:28 PM
  #135
Wink
That's what fixture they obviously tested them on and going down to a 4.250-4.280 will most likely make a reduction in flow numbers . This is exactly why one must be carefully read the fine print and check things out closely when looking at testing and numbers. Dart should go back and run the same test on a 4.250 bore and state whetther they are using a pipe on the exhaust or not? I think Tyler may have flowed them but I am not sure what bore size he used on his tests if he did them.
Still not sure why any Merc 496 owner would want to put heavy (100lbs heavier), lower compression ratio possible ,moderately expensive iron heads on an already fresh water cooled Merc 496 when they could put on aluminum heads., but them I am obviously biased and self serving with that comment!
Good Catch Crayolacrazy!
Best Regards,
Ray @ Raylar
Raylar is offline
Old 03-08-2012 | 07:17 PM
  #136
Best Regards,
Ray @ Raylar
Thanks Ray a little salt in my wound.Im getting a nother set do you want me to ship them to you ,you can test them.
Old 03-09-2012 | 07:30 PM
  #137
Update on the intake on mine.
Pics first
and the raylar
So dynoed it with the raylar and mine withe same parts
stock tb with port job 78mm
stock exhaust manifolds for the rear mount turbo
stock 85mm maf
aftermarket cold air intake for a 5.3
3 inch y pipe into a 4 inch collector then reduced to 3 inch single into turbo to a 5 inch down pipe
single 3 inch to increase velocity to 85mm tv8101 turbo outback
raylar made 390 to the wheels and i want to say 480 torque
my intake made 330 and torque unk probably less due to the shorter runners if you go back and look at pics you can see how short i made them.
zz502 camshaft
h beam rods
mahle forged pistons
The good news
took off 78mm tb and put on 102mm tb and hooked up turbo to my intake
7 lbs of boost 680rwhp
Thats almost 800 flywheel hp
I asked him to give me a dyno sheet with all my sessions superimposed
You should see the drop in midrange NA without the headers on it
Here is the dyno with stock intake and headers and a single 4 inch system stock tb and maf
Oh in all these test the heads are cnc ported by tom at champion.
he did 85 sets of heads for the GM marine engines and he used the same cnc job on these heads.
stock intake size but 11/32nds stems and 1.88 exh valves sense the stock ones are kinda small
I also fell into a set of raylar heads and a forged short block with je pistons and a raylar crank that i will be building for 30 pounds of boost and a bigger cam
cam specs
244/244 @ .050 .650/.650 hydraulic roller
I am going to upgrade the head bolts to 1/2 inch if not bigger and convert the intake bolts to 1/4 inch since finding really long m6 bolts is next to impossible. I actually tig welded 4 bolts to make the length i needed to hold the fuel rails on since i used 4 intake bolts to work double duty.
If you google, 496 into 04 silverado, you can read more about it usually is the first link to come up
Also thanks to raylar for helping me out with some details a few weeks ago when i called. I have another question since i am in afghanistan. What are the cam specs for the 106 cam?
SPC Coss
US Army
currently deployed
xx_ED_xx is offline
Old 03-09-2012 | 10:36 PM
  #138
Rage's Avatar
Send them to Jim Valako to test.
Rage is offline
Old 04-22-2012 | 11:15 PM
  #139
Hey Ed. Are those factory castings or Darts?
jmccart is offline
Old 07-24-2012 | 08:14 PM
  #140
Im hear to tell you darts heads dont flow as good as the cncd heads from Tyler Crocket Im running the same valves in booth and the darts make half pound of boost higher then gm head . I thought they wouldnt need any port work .If any one orders a set make sure you order the bolts stock bolts dont work .
