blower rebuild >
blower rebuild
blower rebuild
Old 01-12-2011 | 10:01 AM
Default blower rebuild
i have an 04 575sci. i need to have the blower rebuilt (it's still all there,just for peace of mind. it has about 160hrs on it) who do you guys recomend? i thought i read on here about a company in wi or mi that did a good job. thx, Tony
HOTRODREDNECK is offline
Old 01-12-2011 | 10:08 AM
Darren Meyers Performance
269-428-5070 ask for Brian
Bearings, Seals, very cheap insurance
spoke to him yesterday there backed up 30 dayz
Old 01-12-2011 | 10:37 AM
not that a rebuild would hurt anything, but thats really not that many hours for that blower. If you are not loosing boost psi, or getting fuel in the blower oil reservoirs, they are probably fine.
You can call
The blower shop
Dyers blowers
superchargers usa
They all rebuild the 256 weiand.
MILD THUNDER is offline
Old 01-12-2011 | 11:04 AM
thx. 30 days dont matter to me it was 2 below zero this morning just trying to stay ahead of the game before they are 60 days behind.
Old 01-12-2011 | 11:05 AM
You are definitely doing the right thing. Mine bearings went with 200 hrs on it and fresh oil. I think the 04s were the B&M sealed bearing version which is not the best design.
I have an earlier Weiand version (oil bath) straight from Merc I would sell if anyone is interested. 20 hrs on it and its true Mercury Blue.
JRider is offline
Old 01-12-2011 | 11:12 AM
the boyz shipped him a 250 yesterday , dont hurt to get in line this time of year .
good luck
Old 01-12-2011 | 10:26 PM
Darrin Myers (DMPE) is in Mi. and the place to go. Brian will fix you up.
Eddie
Young Performance is offline
Old 01-13-2011 | 04:59 AM
Dustin from Whipple recommends normally every 300 to 500hrs runniing for the 3.3. He says the only thing that really needs to be looked at is the rear bearings. Everything else goes alot longer.
campionchase910 is offline
Old 01-13-2011 | 08:47 AM
Kelly O's Avatar
Darren Mayer for sure.
I sent a pair with 180hrs that visually seemed perfect. One had rotors which were slightly out of time, first sign of bearing issue, but caught before any damage. They will modify rear bearing seals to allow better lube of those rear bearings over time. Also they drill and install a drain plug for changing oil in front case.
Have the rotors teflon stripped also. Cheap upgrade to gain about a pound of boost at same rotor rpm.
Kelly O is offline
Old 01-13-2011 | 08:15 PM
thanx guys. i'll be calling brian in the morning.
