need help on a helm/orbital valve i.d. >
Old 01-27-2011 | 12:14 PM
Default need help on a helm/orbital valve i.d.
i am looking at a orbital valve which is a "helm" for a hydraulic system... if you dont know what i am talkling about chances are you wont be able to answer my qustion. i am trying to figure out if the valve i am looking at will work for a single ram hydraulic steering setup. it is a char lynn and tagged 40-97 & 2411071-002
any help would be greatly appreciated!
regalman4925 is offline
Old 01-27-2011 | 03:29 PM
Look on the Eaton site for Steering Control Units (they don't call them orbital valves). I quickly found this:
http://hydraulics.eaton.com/products...CU-TS005-E.pdf and this http://hydraulics.eaton.com/products/steer_main.htm
You should be able to match up what you have, and we have contacted the Eaton reps for work. They were very helpful in answering our inquiries.
apollard is offline
Old 01-27-2011 | 03:33 PM
i have been looking all over on there trying to find the size on this one with no luck. i looked during lunch at work so i will look again tonight. thanks for the help!
Old 01-27-2011 | 07:02 PM
What size cylinder do you have ? What size rod is it 5/8 3/4 or 1 inch?
violator is offline
Old 01-27-2011 | 08:44 PM
Rookie's Avatar
241-1071-0002 is not a Char Lynn part number. But if it is a 241 then it would appear to be an Open Center / Non Load Reaction steering valve, what you need.
http://www.fluidpower.com.br/catalog...n_direcoes.pdf
Rookie is offline
Old 01-28-2011 | 07:06 AM
thats what i dont get, its stamped char lynn.... we are thinking this particular one is not going to be big enough... but from researching yesterday i can decode the model numbers. thought i already had one lined up but we think that the ones we have on hand are too big back to searching. thanks for the help guys!!
Old 01-28-2011 | 08:47 AM
What do you mean ( big enough) . I no I can help. A new one is only $ 300 or so. Cylinder size and rod size that's what I need to no.
violator is offline
Old 01-28-2011 | 08:57 AM
i do not know the size, it cam in the mail last night and didntt havemuc time to look at it. the part number on it is 18183 and its latham. bad thing about latham is there isnt much info out there on their products and so far i have not been able to find specs. it appears to me to be a newer model after comparing it to my buddies older set up he has on his trs drives. the orbital valve i was looking at was off of some golf course size lawn tractor, the ones we have sitting in the shop are for dual rams and the one of them is way too big, the other may work as a temp just to get on the water. you can get new ones for around 300 bucks, the one i asked about was 95 bucks. to a guy like me if i can save 200 bucks doing some research and buying a good used one then that leaves me 200 bucks for something else such as buying trim pumps for my k planes... sorry, i am stingy lol
Old 01-28-2011 | 09:58 AM
Good luck finding a use orbital the will give you the right flow of a single ram set up. Some times good money spent on the right parts goes a long way expescially on steering . I am cheap too. LOL
violator is offline
Old 01-28-2011 | 11:23 AM
Rookie's Avatar
I have posted this link before. Read all 4 pages and you will have a greater understanding of hydraulic steering. It explains the 1 cylinder unbalance Lock To Lock. Also you stated earlier, if you do not understand this you should not be doing it.
http://www.pirate4x4.com/tech/billav...ing/index.html
These are some of the steering valve part #'s you can use. Keep an eye on ebay for these part #'s. I got a new one for about $100.
http://www.midweststeering.com/index...parent=80&pg=1
Rookie is offline
