Update On Oil Lubrication
#31
Based on what I found in other threads the 496HO will use an AC-PF1218 which crosses to the Amsoil Donaldson EAO24. Give me your Merc part number and I will verify that this is correct. If you can tell me how much room you have below the filter, I can see if they have an oversize that will fit in it's place.
#32
The AE024 is what I have used in the past. It is much bigger than the Merc filter. I am using the AE076 this year, just found out about it. It is huge, if your engine is stock probably a overkill.
#34
#35
I was just looking up part numbers today for a couple of boats. Did not know about the EAO-59. The only ones I had been using were the EAO-24 & 25. It seems like when I used the #25 I had to unbolt it from the riser when I used it on the relocator that points down. If it points up you can use the #24. I always like to use the biggest filter possible. The #76 should work the best if you have the room, thanks for the tip. We should get some measurements and post them for reference.
#38
#39
When I was searching out the EAO76 filter for my boat I went to the WIX site and looked up all the filters that would fit a BBC and then went to the Donaldson site and crossed them to Donaldson and checked the specifications of each filter to make sure it was right. Being an Engineer, you always check the source documentation. I had to do the same for my fuel filter the original didn't have a part number or manufacturers name on it so I had to go by dimensions and requirements. I ended up finding an awesome 1qt offroad diesel filter / water seperator good for 10 microns and 15GPM.
