Help, trim sender wires >
Old 05-19-2002 | 03:09 PM
formula31's Avatar
Default Help, trim sender wires
My new trim sender wires have a male and female round connector on black wires instead of the black w/purple sleeve on one of the wires. Which connector is the negative? the male or the female?
formula31 is offline
Old 05-19-2002 | 04:36 PM
blue thunder's Avatar
Formula31... the sender is a variable resistor so I don't think it matters which direction the current flows through. Should get the same result either way.
BT
blue thunder is offline
Old 05-19-2002 | 05:37 PM
formula31's Avatar
I hear ya but one is the wiper and the current flow might matter for life. Since Merc has them polarized I would like to keep it the right way. Darn things are expensive and dont work for long the way they are.
Old 05-19-2002 | 06:13 PM
Polarity in a non motorized, non switching DC application is generally not a problem if reversed. I can't see why it would matter and I suspect that is why both conductors going to the sender are the same color.
Albeit, I understand your desire to do it right. If you are still in search of the answer next weekend I'll take a look on my boat when I go down.
BT
Old 05-19-2002 | 07:36 PM
Blue thunder on the money James
FloridianSon is offline
East Coast B
6
06-03-2007 12:46 PM
waterboy222
Drives and Lower Units
2
06-02-2007 08:28 AM
86formula242ls
05-23-2007 04:40 PM
patrick22309
1
04-24-2003 02:19 PM
formula31
05-19-2002 10:07 PM
