Small rocks in oil filler tube???
Not sure if its the same with marine engines, but I know with car engines there is a screen over the sump pump. And I figured if there are more rocks in there, they would sway with the oil. The boat ran great the 2 times I took it out, and oil pressure was good the entire time.
Hell if it blows, thats just an excuse for me to get the 525 I want
I also had a 250 Enduro. Great bike, but primitive by todays standard. I now have a KX500 and it is a monster compared to the old Yamaha. I also had a 250MX if you remember those. I guess we are both old. lol
Are you sure they are "rocks"? Could they be little pieces of metal, carbon, etc that actually were in the engine and blown up in the filler neck. I have seen old worn out engines steaming and venting out the oil fill neck. Have you cleaned one off to make sure it is a rock?
I'd think any rocks that made it into the oil pan via the dipstick tube, will just lay there and not cause any harm. But I would for sure pull the valve covers to make sure none were dropped in thru the vents caps. Any rocks up there can be a problem.
Why did you fill oil thru the dipstick tube instead of the fill cap?
Good luck with your engine, I have blew mine up many times. The rocks would most likely not make it through the screen on the pickup tube. I would pull the engine, drop the pan, look at the oil cooler and go through the entire oil system. Let us know what you find out.
I was thinking that you could have taken a sample of the oil and had it analyzed- let the lab know what you found and they might be able to give you some insight as to what they see on a oil analysis. For about $25 it might give you piece of mind.
