Perko flush
Old 05-23-2002 | 03:50 PM
rtn137's Avatar
Default Perko flush
Anyone using one of these or something similar?
Does it flow enough for a HP500 EFI when in the water or does it restrict some of the flow?
What hose diameter on 500 EFI?
rtn137 is offline
Old 05-24-2002 | 12:11 AM
Blackhawkdn
Use a 3/4" hose for flushing your engine. Just make sure you have sufficient water pressure at your hose bib at least 35psi. When you flush your engine keep your rpms at about 1000 to 1200 rpm
Old 05-25-2002 | 08:51 AM
GregP's Avatar
Also make sure you don't have too much water pressure. I have almost 100 psi at the dock, and if I don't leave the hull pickups open a little to vent the pressure you can actually cause a raw water pump impeller vane to "reverese", which will trash it pretty quick once you start the motor.
-Greg
GregP is offline
Old 05-25-2002 | 08:41 PM
Takin Off 1
Work Fine.
I have one on my HP500. Pressures good and temp is perfect. I'm running a crossover and restrictor plate.
Old 05-26-2002 | 08:48 PM
GregP's Avatar
Can't tell from the photo if it is like the ones that were on my Donzi. They were made so the flush pressure would push a plunger and close off the raw water feed. I had a couple times when they stuck "closed" (spring is supposed to open them once the flush hose is removed). I was able to catch it fairly quickly as I always check for water flow as soon as the motors start. A quick look at the transom saved a problem.
-Greg
GregP is offline
Old 05-28-2002 | 07:30 AM
klmken's Avatar
Exclamation Warning!!
Make sure that you plumb this unit before the raw water impeller in your system. If not you will wind up roasting the impeller unless you remove the belt from the belt driven models....I'm not sure how this would work for folks with outdrive water pumps....
Ken
klmken is offline
scottsumrall
6
03-24-2008 11:41 AM
88Fount33
1
07-28-2006 04:18 PM
miamioffshore
Cigarette
4
04-11-2006 06:50 AM
Kentz
Powerquest
19
06-10-2003 05:45 PM
Julio
Powerquest
3
02-22-2002 07:34 AM
