Distributor Gear Failure on 454 Mag EFI >
Old 10-16-2017 | 07:31 PM
  #151
Originally Posted by caldera
Im not sure about another engine now. How to avoid same problem? If leftside was ****@up maybe right side is also in bad condition.
Always watch oil pressure and water temps. If the other engine got you back it's probably ok. Unless you want to rebuild it just leave it alone
veloc410 is offline
Old 10-16-2017 | 07:42 PM
  #152
Then again it is the right time of year to pull engines. Look at here😐 ISSUES
veloc410 is offline
Old 10-16-2017 | 08:14 PM
  #153
So what is the big pipe elbow on top of the thermo housings?
dereknkathy is offline
Old 10-16-2017 | 08:21 PM
  #154
Originally Posted by veloc410
So the konrads 540 would need the right trannies to get them spinning in .? They are controlled by transmission I've heard.
So Konrad don't have left and right lowers like the TRS they replaced? Cuz Borg Velvet Drives turn the same way the motor does. You gotta flip front pump around for opposite rotation, but you can't just put it in reverse like a bravo and use right hand prop. In fact, reverse isn't even same ratio as forward.
Old 10-16-2017 | 08:33 PM
  #155
This is the mod I did. The copper tube separates fresh and hot water, thermostat is in the intake manifold under the housing and temp sender is also in the intake. I bored out the ledge that the thermostat sits on, the copper tube sits on bottom ledge and is even with top of housing and the cap holds it down. The elbow is the hot water exiting o it transom next to exhaust tip.
veloc410 is offline
Old 10-16-2017 | 08:44 PM
  #156
This cap is ugly but temporary and experimental. I am making replacement caps out of thick aluminum or stainless plate to replace them. I'm seriously coconsidering ditching the water pumps for crossover tubes. Dont really need the pumps unless closed cooling is used. Water now feeds exhaust manifold from bottom only. They are way cooler now which means more air flow.
veloc410 is offline
Old 10-16-2017 | 08:49 PM
  #157
oh good to know. So doing a bravo konrads swap is a pain
veloc410 is offline
Old 10-16-2017 | 08:56 PM
  #158
yes the paint is coming off the valve covers, like that when I acquired boat. I need taller covers so may not refinish. Using double gaskets .
veloc410 is offline
Old 10-17-2017 | 04:03 AM
  #159
caldera is offline
Old 10-17-2017 | 04:04 AM
  #160
caldera is offline
