Distributor Gear Failure on 454 Mag EFI >
Old 10-17-2017 | 04:59 PM
  #171
Originally Posted by veloc410
Maybe it will be ok. It isn't a fast boat
For 14 000 lb boat 35 knot is good speed...
caldera is offline
Old 10-17-2017 | 05:26 PM
  #172
Lol that's a good speed for that boat but it's still a sled. No offense intended . Probably be fine
veloc410 is offline
Old 10-17-2017 | 06:28 PM
  #173
25 tops sensible speed. And Two shafts with quite a bit of distance between them I don't think I'll make anything at all difficult docking. At slow speed you don't even use the rudders on this boat. You just drive it like a bulldozer.
dereknkathy is offline
Old 10-17-2017 | 06:57 PM
  #174
Such a shame! Okey i want to hear jasper funs now.
caldera is offline
Old 10-17-2017 | 06:59 PM
  #175
I sent them almost every single serial number but...
caldera is offline
Old 10-17-2017 | 10:41 PM
  #176
i seriously doubt that boat weighs 14,000 lbs.
mike tkach is offline
Old 10-17-2017 | 11:54 PM
  #177
my hatteras is 12,500. this is about 9000.
Old 10-18-2017 | 08:14 AM
  #178
Why not try the easy way?
https://www.ebay.com/itm/CHEVY-350-87-95-MARINE-REMANUFACTURED-ENGINE-Reverse-Rotation-/142055257379?hash=item2113273523:g:N6cAAOSwqfNXiOv v&vxp=mtr
Good luck.
Also: Why no mention of changing/cleaning remote oil coolers and or oil filters and lines.
GLENAMY 242SS is offline
Old 10-18-2017 | 08:42 AM
  #179
https://www.ebay.com/itm/CHEVY-350-8...NXiOvv&vxp=mtr
Good luck.
Im sure everything will get cleaned out. .
veloc410 is offline
Old 10-18-2017 | 08:55 AM
  #180
So his props are Ok? And are those props easy to find. I'm thinking if he goes standard rotation, he will be able to use his original distributor. He mentioned a gear instated of chain for timing. So crankshaft spins opposite and cam spins standard . Just the cam lobes are oriented so they open valves at proper time. But he would need starter
Maybe alternator. Does he have the seawater pumps like I have on the bravo. If so they can run either direction, just switch hoses Think recirculating pump is bidirectional. Are the belts set up the same or are the routed so accessories run standard. ??? Also if speaking to the person at jasper im sure they can get him the right engine
veloc410 is offline
