Distributor Gear Failure on 454 Mag EFI
#181
Why not try the easy way?
https://www.ebay.com/itm/CHEVY-350-8...NXiOvv&vxp=mtr
Good luck.
Also: Why no mention of changing/cleaning remote oil coolers and or oil filters and lines.
Good luck.
#182
They sent me close-ups of his engine before he pulled the Pistons out. The notch that points to the front of the engine was pointing to the back of the engine. Means you don't just throw a new cam and a rear seal in it you take out the Pistons put them in backwards, or maybe take the Pistons off the rods and turn everything around and put it all in backwards. Which means buying a rebuilt to change over is muy estupido. (Not russian.) There is also a 1090 plus 250 ship short block reverse cam specs match merc 260. Need lifters, oil pump, gaskets. So, in to about 1500 and still gotta clean up his heads.
#185
5.7L (350ci) Base Marine Engine (1967-1986 Replacement)
They say this is what i have and what i need.
#186
I've seen this thread continue to go to the top and never daily and couldn't understand why until tonight. I finally read through it. Initially I skipped around a bit however went back to read and LOOK at all the post. Wow... wish you luck caldera (chit happens). I've seen some pretty messed up internals but that's right up there with the worst of them without question. Also wanted to compliment D&K. He is a good man. It's Nice to see others offer to help in anyway they can.
#187
So new engine i get in next week. I have 1 week to clean and paint everything...
#189
Well i finally finish with trans and starter... All painted.. I still have intake and manifold/risers and also small staff like distributor, coil, carb etc..
I also sprayed degraser in engine room... Needs cleaning and painting..
New engine comes Wednesday or Thursday.
#190
Now, Dave (Caldera) has a bit of an issue. His boat is still in the water tied to the dock in Mill Basin in New York City. He took the motor out by taking it apart and lifting the block out by hand. Possible but potentially not good for ones back with a small block. Now he's getting a complete engine. I don't think he wants to tear the heads off to put it back in by hand and then reassemble it. Does anybody have any thoughts on how this install can be done? I'm thinking maybe build a little wooden Gantry that sits on his deck right above the engines. But that still requires getting the engine down the dock and over the gunwale and into the boat.
