-   -   Distributor Gear Failure on 454 Mag EFI (https://www.offshoreonly.com/forums/general-q/25280-distributor-gear-failure-454-mag-efi.html)
caldera 10-06-2017 10:08 PM
Originally Posted by dereknkathy (Post 4586634)
As much as I try to talk people thru the leave-it-in-place method, if you can disconnect the transmissions and leave in place, this will be way easier not doing a head stand next to the engine to get down there. But sometimes you have to cut the coupler bolts and trans mounts can be salted up pretty good till they can't be unbolted. Then pulling engine-trans together could be a huge pain. But generally, you can support the trans from above, unbolt trans from engine and unbolt engine from front mounts leaving them in place. Also EVERY TIME you pull a shaft engine, you are supposed to do the feeler gauge thing getting engine-trans lined up to within a couple thousandths. But leaving all mounts untouched is your best bet at popping the motor back in and driving away. Worst case scenario if it don't feel right after putting it in the water, you use second engine to get up enough speed for running on 1 engine and rudder, and docking.
1 engine is completely enough for docking. I did couple of times already .
caldera 10-06-2017 10:13 PM
Question for experienced boat owners.
When u take out headers it needs special sanding alignment or it goes back without it?
dereknkathy 10-07-2017 04:17 AM
Where are you from? Just for language barrier confusion. Now, headers. You don't have headers, only exhaust manifolds. They require some but not a lot of gasket face cleaning. Cylinder heads? You probably don't need to remove them, but they take a lot of cleaning-prepping before reinstallation. But rarely do they have to go to machine shop for resurfacing, which is what I think you mean. Now, you called these 454 mag engines. The picture shows a 260 hp 350 small block. Good motors. I thought a 27 fishing boat was a bit overpowered with 2 454 big blocks. Tried to look up your serial number. It didn't come up.
SB 10-07-2017 06:07 AM
^^^^Engine pics are small blocks too. BTW: I clicked on one of his pics the other day and it goes to some Russian photo hosting sight. Stopped clicking on them just in case.
caldera 10-07-2017 06:33 AM
Yes cylinder heads resurfacing.
im from country of Georgia. Sorry but i was born in soviet union...
caldera 10-07-2017 06:36 AM
I used local forums long time ago so remember hosting site for upload pictures. Whats wrong with it? Next time i remove [url] so no more clicks just picture.
SB 10-07-2017 06:54 AM
Again, just in case. Since this site did an 'upgrade' a little while ago, the security has gone down. Don't take it personal. :)
dereknkathy 10-07-2017 07:18 AM
You don't need to apologize for being born in the CCCP. If anybody owes the world an apology it is Karl Marx and Vladimir Lenin. It was their brilliant idea...
caldera 10-07-2017 08:15 AM
Okey guys. Im in marina and continue my work around engine. Risers, manifolds, cooling system, distributor (timing priority saved for any case), coil are out from the engine.
Bad thing is that cant take out transmission separate because its second mount for engine... looks like i need to pull out whole engine.. Any ideas?
caldera 10-07-2017 09:04 AM
http://s018.radikal.ru/i519/1710/b8/d6259319c21d.jpg
