Carb HP500 Oil Overheating? >
Old 05-27-2011 | 02:41 PM
Originally Posted by Eliminator28
The pic is of the remote oil filter pad. On the back of the engine, port side (where your oil filter goes on). the lines sticking up in the air in the pic are actually facing towards the starboard side of the engine, and connecting to the oil cooler.
You do understand I'm talking about the oil cooler thermostat and not the engine water thermostat right?
This filter pad is mounted to the back of the port side head. NOT down where the original oil filter would go if it was in a car...
Got it. thanks for clarification. will try that first. any idea where water t-stat is?
Fool Throttle22 is offline
Old 05-27-2011 | 02:45 PM
blue thunder's Avatar
Its on the front of the intake manifold and under your lifting ring. No need to go there though, its working fine.
blue thunder is offline
Old 05-27-2011 | 02:51 PM
X2
Eliminator28 is offline
Old 05-27-2011 | 03:04 PM
sounds like the relieve valve in the block hung open and not sending the oil thru cooler..or still has 11psi relief valve in there
ezstriper is offline
Not engine thermostat people stop saying that. When your ac goes out you don't fix the furnace. OIL Thermostat. And lean wouldn't really do it either only other thing too much timing or dist gear out.
GTOFFSHORE is offline
Old 05-27-2011 | 04:01 PM
Why is nobody mentioning the obvious...at 280 degrees your buzzer alarms would be screaming. Are they going off? Take the ground off the gauge and check it with the motor running.
First make sure your alarams work by turning the key to the on position (don't start it) and within 5 second or so you will hear an alarm go off.
Also, maybe the needle/gauge is stuck. I still say bad ground like when a tach doesn't read right. Try tapping on the gauge when it hot to see if it moves at all. Sounds like simple fix if your alarms aren't going off.
Try the basic stuff first before you start pulling coolers, filters and thermostats off the motor.
Flapjack is offline
Old 05-27-2011 | 04:33 PM
Oil temp... 280 degrees of oil temp... Theres no alarm for oil temp.
Whole lotta confusion going on in this thread... Water vs. oil.
cubicinches is offline
Old 05-27-2011 | 05:00 PM
agreed.
I would start with a new filter first. I have seen them collapse at high rpms.
cabin fever is offline
Old 05-27-2011 | 05:06 PM
There are alarms on oil temps, check around.
Flapjack is offline
Old 05-27-2011 | 05:09 PM
Not in any stock HP500 carb engine there isn't.
