Carb HP500 Oil Overheating?
#31
#32
I'm pretty sure I have a bad gauge or gauge connection. The eng oil seem like it should have got a little burnt or darker color but still looks like honey. I'm going to put a temperature laser on the oil filter and a few other places to confirm.
#33
Any chance you could just swap sensors between the engines? Or an easier check might be to swap the wire connections - you could probably fab up a couple of extensions from some wire and solderless terminals. If the other gauge starts reading high, you have isolated your problem to the sender. However, it's unusual for a sender to go bad like that. Laser temp gun might tell you something, but it can give a false reading as well. Maybe you could get a comparative reading between the two engines. Point it at each oil pan, and see if you get a significantly higher reading.
#34
carb HP500..do these engines come with oil thermostats? if so, where are they located? I have good water temp, good oil pressure, just oi temp goes high quickly, other motors run cool oil temps??
#35
Water Presure is at 20psi just like port eng, Water temp is 130 degrees just like Port eng but Oil temp stays at about 220-230 at cruise and got up to 280 at full throttle. I immediately came to idle and it went back down to 220. Port eng never gets above 180 degrees. Where should i start to look for this issue? Sticking Thermostat? Trash clogging water impeller pump? Any help would be appreciated. Also, I just had the oil changed and since it got up to 280, do you think the oil is now bad?
Thanks.
Thanks.
#39
ok, thanks guys... the t stat had some crud on it, I ordered a new one.. but may not have in time for the weekend , I did clean up the old one & it now expands in a pot of boiling water .. should get me by for now
