Funny noise when shifting Bravo into reverse >
Old 06-01-2002 | 08:50 PM
djm's Avatar
djm
Thumbs down Funny noise when shifting Bravo into reverse
Shifting to/from forward, it goes "clunk" and that's all. Shifting into reverse gets a "clunk clunk". What is that? How do I fix it? Shifting from reverse to neutral is a normal, "clunk".
djm is offline
Old 06-01-2002 | 11:11 PM
Tinkerer's Avatar
Funny -- I never hear any "clunk"
Tinkerer is offline
Old 06-03-2002 | 04:41 PM
djm's Avatar
djm
bump
djm is offline
Old 06-03-2002 | 08:25 PM
blue thunder's Avatar
No clunks here either. What is your idle rpm set at?
BT
blue thunder is offline
Old 06-04-2002 | 09:17 AM
djm's Avatar
djm
The guage says the idle is between 600 and 700. A clunk can be taken a couple different ways, so let me just say it makes a noise when I put it in forward gear, a normal noise. But when I put it in reverse it makes two noises. Is it something that is affected when the drive is removed and reinstalled?
djm is offline
Old 06-04-2002 | 09:41 AM
formula31's Avatar
I hope what your hearing is not the vertical shaft. I remember hearing that double thunk when I shifted into reverse once. The vertical shaft broke at 5000 rpm about 10 minutes later. Might not be related. Id ask one of the drive guys at doller marine. Just a stupid question but make sure the prop is tight. Sometimes the thrush washer gets trashed and the prop can move forward and aft. GGod Luck. Hope its nothing.
formula31 is offline
Old 06-07-2002 | 06:28 AM
sterndrivespec's Avatar
i agree,check the prop first.
sterndrivespec is offline
CN24
Drives and Lower Units
3
08-06-2007 09:14 PM
sightunseen
1
08-03-2005 08:13 PM
MnFastBoat
7
08-02-2004 05:27 PM
bowtie89
4
04-17-2004 09:48 AM
dap100
2
07-28-2003 04:00 PM
