Procharger idler bracket/ modifications questions >
Old 08-15-2011 | 07:52 PM
GPM
I thought Randy was going to EFI
GPM is offline
Old 08-15-2011 | 07:56 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Originally Posted by articfriends
I run 12-15 psi of boost depending on air density and my upper pulley choice. I am definately going to look at having Reichard groove my upper pulleys as I have heard you can run much less belt tension at same boost levels, could never get them to call me back last time I was looking at this, called them today again now that I am re-visting this and got the same thing I did a few years ago though, voice mail, Smitty
There is a guy on ebay, that will cut your pulley for a few bucks, rather then buy one of them $$$$ ones.. Also not sure how you have your set up configured, but if you are using a idler pully, is there any way to drill a new hole mount for it in the bracket to give you more pulley wrap?? Just thought, that is what I did on my set up on my truck.. I am currently running 12 psi on my truck on a 6 rib kit, with 0 slip, but I have a ton of pulley wrap..
Here is the guy on ebay, this might be worth a shot..
http://cgi.ebay.com/ebaymotors/Proch...item4cec028611
John jr
Fenderjack is offline
Old 08-16-2011 | 02:06 AM
articfriends's Avatar
Randy is going to, I just got him a smoking deal on efi harnesses and ecu's, Smitty
articfriends is offline
Old 08-16-2011 | 02:08 AM
John jr
Thanks, Smitty
Old 08-17-2011 | 02:47 AM
Still never heard back from Reichard racing about machining the pulleys or their billet bracket, I did order a M-5 idler today from Procharger after CNC sent me a pic of his, it looks drastically better than the junk I been using, Smitty
Attached Thumbnails Procharger idler bracket/ modifications questions-dsc01818.jpg   Procharger idler bracket/ modifications questions-dsc02966.jpg
Old 08-17-2011 | 07:01 AM
Smitty, I like the looks of that, doing away with that swing tensioner....strait push should be much stronger...good luck and thanks for your help with my pulley deal...Rob
ezstriper is offline
Old 08-17-2011 | 08:15 AM
Rob, your pulley and belt went in mail yesterday, Smitty
Old 08-17-2011 | 06:06 PM
GPM
[QUOTE=articfriends;3480804]Still never heard back from Reichard racing about machining the pulleys or their billet bracket, I did order a M-5 idler today from Procharger after CNC sent me a pic of his, it looks drastically better than the junk I been using, Smitty[/QUOTE
Nice picture, that's my M4 and bracket.
GPM is offline
Old 08-17-2011 | 06:20 PM
And it's been put to good use!!!
Old 08-17-2011 | 07:04 PM
GPM
That's a good thing! How's the boat running Randy ?
GPM is offline
