Bottom Paint ermoval >
Old 09-29-2011 | 03:58 PM
fantastixvoyage's Avatar
Tried the easy off without much luck, all it did was clean it. Must only work on certain types. I had planned to sand off and use the interlux performance epoxy but would rather save the gel if I dont have to spend hours and hours sanding and polishing. Will try a spot with the stripper next
If anyone else has a favorite technique post away. Media blasting was a grand plus need to sand and polish for sure.
fantastixvoyage is offline
Old 10-04-2011 | 07:59 PM
Carbon Footprint's Avatar
I still think you should just sand and compound it........... you could do it in a weekend +1day if you stick with it. It's not as bad as people think, I've done several 30 footers. The EasyOff looks pretty nasty! but if it works, hey I might have to give it a try!!
Good luck which ever route you take.
Carbon Footprint is offline
Old 10-04-2011 | 08:15 PM
I had a similar project last summer and tried everything listed here. I had the best results with Behr Deck Stripper and and rototip powerwash nozzle. It took 99% off and my paint was THICK!
endeavour32 is offline
Old 11-10-2011 | 01:43 PM
Update:
Tried the Easy off, no luck. Tried the mild reccomended stripper with better than prvoius.
Last tried the suggested Deck Stripper and it worked the best. I will still be taking it in for a light sand and polish. Howeevr saving myself a lot as the work is now minimal.
Did not have BBehr brand so I used Jomax from Lowes dispensing from a garden sprayer and hit it with power washer. Will try to post up some pics soon.
aven2rus is offline
