VORTECPRO VS Bob Madera/Haxby
#81
Yes Ive been quiet, Friday I called Bob to bust his balls, and after talking to Bob, and getting my ass chewed, Bobs enthusiasm for engines made me realize he likes engines just like myself, I shouldnt be holding a grudge because my dyno numbers were questioned, so I aplogize to the forum and Bob, and you to Bill, I was out of line. So theres still some question about the dyno numbers, Bob you told me to present you with the data so you can decide if the numbers are right, I would very much like to take you up on that, I would appreciate it.
I can respect that statement.
#82
I say let's still conduct the dyno test and put some finality on this thing!!!
As long as this whole thing has gotten everyone's attention why don't Madara and Vortechpro still conduct the dyno test just for arguement's sake??? That way it can put some of these arguements to rest (at least to some degree) for any future arguements.
#84
i think the dyno test would be a waste of time as the motors are built for 2 different types of use. Tune a motor for max power and then take it and make a power pull for even 5 min's and you stand a good chance of detonating it to death. Also it will take a good dyno to be able to hold a motor for 20 min. This was a competion that VP could not win if he was set up for max power and i think he figured that out.
#86
Dang! I wanted to see a shootout. Oh well VP is right about most of us having a love for making power and having fast stuff. I'm not saying we need to stick together, but to argue or debate to the point of getting furious is silly.
#87
Called out by Bob Madera/ Haxby to an engine edurance test. Rules: 454 production block, 454 production heads, any thing else goes. Testing procedure: Haxby/Madera will make one HP dyno pull, then run at 6500 RPM for 20 minutes under full load. The water will then be changed and Vortecpro will follow the same test, which ever engine finishes the test will win, if both engines finish the (endurance test) the highest HP will win. Fuel will be 89 octane as speced by Haxby, 10,000 dollars will be held 30 days in advance (prior to the test) by Mike Lewis, winner takes all. The test shall be conducted at Westec in Ca.
#88
This is his MO on multiple sites. when things don't go the way he wants, he tries to misdirect or just posts the same cut/paste over and over. As I said before, he bogus challenge was accepted using the Outerlimits dyno. Then he wanted to change all the rules, and add $10K bets etc etc. Long story short he never showed. Just like he won't here.
http://youtu.be/qZeG-bhe4_w
video of his high tech dyno room.
#89
Reading the entire thread before quoting out of context, and you would understand better. BTW, where did I say what it was or wasn't? and no one cares what it did or didn't cost. I can buy a million dollar CNC machine The fact that I don't know how to use it might affect its outcome.
#90
