Bravo Gear Lube >
Bravo Gear Lube
Bravo Gear Lube
Old 10-02-2011 | 07:39 PM
bowtie's Avatar
Merc HP gear lube is synthetic.
bowtie is offline
Old 10-02-2011 | 08:01 PM
Originally Posted by weldcrane
imco recomends torco in there drives any reason why?
When i first ran my SCX's i used Merc gear lube (less than an hour) but the drives shifted to hard. Call Imco and they picked them up to see what was wrong. They told me that their drives need the TORCO ATF which is thinner than the Merc fluid thats why the hard shifts. When i got the drives back they did shift easier with the Torco.
Advantage 575 is offline
Old 10-03-2011 | 07:06 AM
I dont think it is..
boatnt is online now
Old 10-03-2011 | 07:27 AM
Knot 4 Me's Avatar
Originally Posted by Young Performance
I build a fair amount of Bravo drives that go behind some decent sized engines (some well over 1000 ft lbs of torque). By no means am I an expert on drives. However, I have had some very good luck with them staying together. I have been using the Merc HP lube with a gear lube additive from Pro Blend. I've noticed 30-40 deg. drops in oil temp and a huge reduction in pitting of the gears. That's what I have seen as the biggest cause of failures with built drives. The stock XR's seem to break one of the shafts before the gears go.
I've tried Mobil 1 gear lube with the Pro Blend and had a problem with clutches hanging up and sticking. After a hard run they wouldn't come out of gear. If they did, then they wouldn't go back in gear. Most of them would need the forward gears replaced with the clutch since the clutch would tear them up.
I'm sure there are other good choices for lube but this has worked for me.
Eddie
You use the Pro-Tuff gear lube additive? How many ounces per drive?
Knot 4 Me is offline
Old 10-03-2011 | 10:05 AM
I have a 2 gallon pumper upper filler thingy that I fill the drives with. That's a technical term by the way.
I put 4 ounces of additive per quart of gear lube.
I use all of their stuff....assembly lube, oil additive, grease, etc. Really good stuff.
Eddie
Young Performance is offline
Old 10-03-2011 | 10:28 AM
Knot 4 Me's Avatar
Eddie
Thanks! I have a 3 gallon pumper upper filler thingy. Made by Stevens. Pic at bottom of link.
http://www.stevensinstrument.com/gearcase.htm
Old 10-03-2011 | 11:54 AM
It is a synthetic blend
Griff is offline
Old 10-03-2011 | 04:31 PM
Alisyn Pro 21 zero weight gear lube.
Anyone familer with this stuff? I was advising a guy on another forum to stick with what worked. He thinks he can get another 50 rpm just by switching from merc HP to this stuff and I don't believe it.
NightHawk is offline
Old 10-03-2011 | 04:43 PM
That one is nice. I just made mine from a 2 gallon Chapin garden sprayer. It works great in summer, but it's slow in the winter when it's trying to pump pancake syrup.
Eddie
Old 10-03-2011 | 05:54 PM
SFOcean's Avatar
Charter Member #394
Oh, no - now the Pro Tuff secret is out.
Been using the Pro Blend products for decades now; no oil related failures in anything.
SFOcean is offline
