EFI for everyone >
EFI for everyone
EFI for everyone
Old 07-29-2016 | 08:51 PM
  #461
The stock Gm single wire is the one most use. I used stock 502mag on my last build and same part number on my current build.
indysupra is offline
Old 07-30-2016 | 08:47 AM
  #462
Rage's Avatar
What knock sensor frequency do you use in the Holley set up?
Rage is offline
Old 07-30-2016 | 07:37 PM
  #463
Rookie's Avatar
Originally Posted by offthefront
Dang ..... wish someone had told me ..... been running holley since 2012
https://youtu.be/t3c098nuV4Y
Closed loop ... 4 years no issues ... is HP though ....
If you refer to the system I was referring to, to the other member, you can not run boost.
The Sniper EFI system will not do it.
And your Youtube vid didn't work! I need to see some engines running
Rookie is offline
Old 08-20-2016 | 06:11 PM
  #464
Rage's Avatar
Anybody out there running the Holley HP EFI on a Mercruiser 496HO based engine?
Rage is offline
Old 08-22-2016 | 02:28 PM
  #465
hammerdown500's Avatar
I may have missed this in an earlier comment
But what about converting or connecting the ecm and engine harness to the existing boat harness. How hard is it to make the big plug conversion
hammerdown500 is offline
Old 08-22-2016 | 03:54 PM
  #466
Also does anyone have any experience with using the fast efi 2.0
setup on our mpi ramjet intakes
Old 08-22-2016 | 06:27 PM
  #467
Fairly straight forward, depending on what you are starting with. I just say that because the 502 charging harness and the 500EFI charging harness are different. But on mine, the 500.. There is a Key on, tach, blue with tan and tan with blue for alarms and temp. The 500 has water temp going thru the ECU, so its slightly different. Then you make the plug on the other end to match the Holley pigtails.
launchpad475 is offline
Old 10-11-2016 | 07:15 AM
  #468
Tibbstoy2's Avatar
Originally Posted by HaxbySpeed
To get really consistent shifting, especially with a big prop, it's best to tune the idle portion manually. I usually set the closed loop 200-300rpm above idle rpm.
I made the switch a couple years ago from Bravo drives to Arnesons (with BAM transmissions) and I turn 34p 18" diameter SSM #6 props. Shifting in gear usually causes a stall (drops RPM from 1000 to 500) - IF I don't touch the throttle. I've learned to bump the throttle slightly (more air) and it reacts normally without a change in RPM. It seems the IAC doesn't react quickly enough to overcome this. The issue here is you need to have lots of hands in a tough docking situation.
I run the HP EFI on my NA 540's with multiport injection and DIS ignition. My cams aren't too wild, but the engines currently don't like to idle much below 600 (with carbs 750 used to be iffy).
I'm curious what idle tuning you can do to help big-propped boats fine tune this and counteract the stall? I've tried several techniques, curious what the pro's do?
Tibbstoy2 is offline
Old 10-11-2016 | 08:15 AM
  #469
This is what solved the stalling for me and I was taught about this by Alex Haxby . On the timing table note which cells you idle in. I set the timing to about 8 degrees in these cells. Now I look at the cells I move to when I bump the boat into gear. I advance the timing to 22 degrees in those cells. The timing will react much quicker than the IAC motor and help save the stall.
hadleycat is offline
Old 10-11-2016 | 09:29 AM
  #470
Tibb like Hadley stated its all in the timing. I've got 33's on my fountain and it took 20-30 min to get both motors acting right in and out of gear. I run more than 22deg in gear and that has helped me. If you need any help your more than welcome to call me. 317-538-3100. Haxby has saved me tons of time over the last two builds. He is the man!!
