EFI for everyone >
EFI for everyone
EFI for everyone
Old 12-17-2018 | 02:57 PM
  #501
Do I need any of my connectors from the factory wire harness? It a Mefi 3 system. I'm trying to sell my complete 500 efi system and want to make sure I don't part with anything I need. Thanks! Great post!!
Del Flores is offline
Old 05-12-2019 | 07:05 PM
  #502
Rookie's Avatar
Just put together 2 Holley HP EFI systems. Anyone out there using their stock Thunderbolt distributor and a Crane HI-6M box? Just looking to properly wire up my ignition.
Rookie is offline
Old 05-13-2019 | 05:43 AM
  #503
What is the Crane HI-6M box for? Is the Thunderbolt distributor an HEI style?
Regards,
Del Flores.
Old 05-13-2019 | 04:16 PM
  #504
Rookie's Avatar
HI-6M is a Crane programmable CD ignition box. The Thunderblot is not an HEI, it uses an external coil.
Rookie is offline
Old 05-13-2019 | 04:19 PM
  #505
Rookie's Avatar
After looking over the instructions I noticed the illustration that notes the Crane HI-6 should be connected just like the MSD-6 using the loose white wire if ECU is going to control timing..Just trying to be a little overly cautious.
I assume the Thunderbolt is magnetic pick up (2 wire) distributor? It is not hall effect (3 wire)
Rookie is offline
Old 05-13-2019 | 04:37 PM
  #506
SB
Thunderbolt is Hall Effect. That's why the rotor has a wheel with square 'windows',
The EST is magnetic
SB is offline
Old 05-13-2019 | 08:33 PM
  #507
Rookie's Avatar
Here are a couple of quotes I found describing the TBolt distributor.
"The sensor uses a hall effect transistor and a magnet to sense when to fire the coil."
"Uses a Hall-Effect type sensor to trigger ignition accurately even at extremely low RPM."
I was thinking it was like page 17 of the following PDF maybe page 19, but not enough wires.
https://documents.holley.com/techlib...10555rev16.pdf
Rookie is offline
Old 05-14-2019 | 07:36 AM
  #508
SB
The White/red wire going to the TbboltIV sensor is 12V ign+. The green / white is the hall effect signal out.
As you know the TboltIV pickup has it's own ground that goes from sensor to block.
BTW: Hall Effect pick up does use a magnet, but don't let this confuse a Hall Effect Pick Up with a Magnetic pickUp.
SB is offline
Old 05-22-2019 | 03:51 AM
  #509
Hey Hax,
Tryed to PM you your inbox is full,I interested in buying the HP from you.
AusScarab29 is offline
Old 05-22-2019 | 08:40 PM
  #510
Rookie's Avatar
Originally Posted by AusScarab29
Hey Hax,
He hasn't been logged into the site in a year.
Rookie is offline
