Hyd hose on cooler >
Hyd hose on cooler
Hyd hose on cooler
Old 11-26-2011 | 11:07 AM
Default Hyd hose on cooler
finishing my inside Hyd steering install, cannot get the H/D hose supplied in the kit to go on the slip on filling on the cooler..only slip fit in the system...fitting made on cooler so can't change that..any idea's ? thanks Rob
ezstriper is offline
Old 11-26-2011 | 02:44 PM
Rookie's Avatar
That is the low pressure side right? I just used braided rubber hose from the local auto store. I think 3/8" rubber gas line.
Rookie is offline
Old 11-27-2011 | 09:08 AM
Hate to have to change the whole hose..15' or more..goes all the way to the helm..plus would have to change the fitting there as well....
Old 11-27-2011 | 09:46 AM
C_Spray's Avatar
Diamond Member #001
Use an hosebarb-to-hosebarb adapter to go to the right size. Tuck it out of sight so it doesn't show, but you can still access it.
C_Spray is offline
Old 11-28-2011 | 05:48 AM
thanks, thats what I ended up doing..could not get the hose to slid on now matter what...found I have one hose end that did not seal !!!! but had to get winterized...cold coming !!
