Hydrolocked my motor >
Old 12-19-2011 | 01:53 AM
You said the engine hydrolocked, but then you say that you pulled all the plugs and there was no water in the cylinders. It sounds like you could have multiple issues. The Merc Gils were very susceptible to reversion, especially in the earlier years before they changed the risers.
If you've got 80psi and are not seeing any leaks, then the manifolds are fine. They only see about 3psi at idle.
Originally Posted by tcelano
I'd bet the riser/elbow went bad. What did the manifold/riser gasket look like?
If not those, then the only other answer is reversion. You could have hit some harmonic holding it at 1500 that sucked water down, but the exhaust pressure kept it from entering the exhaust valve. Once you dropped back to idle, there would have been much less exhaust gas velocity coming out of the cylinder, with the exh valve staying open longer, allowing it to flood.
It is a dry joint. Water passes between via a hose.
Griff is offline
Old 12-19-2011 | 06:15 AM
did you spin it over with the plugs out ?? should have...sounds weird to hydro-lock while running like that ??
ezstriper is offline
Old 12-19-2011 | 07:12 AM
Check the risers, I had one gone bad just above the hose bung.
Agree with Griff, odd that you did not find any water in the cylinders.
badluck is offline
Old 12-19-2011 | 07:53 AM
Knot 4 Me's Avatar
Merc had a bulliten out awhile back on running their motors on a garden hose. They recommended @ 1,200 RPM and not to have a ton of water pressure coming out of the hose. When you backed off the lower RPM and high water pressure could have reverted water. Are you sure it didn't just drop a couple of cylinders and die?
Knot 4 Me is offline
Old 12-19-2011 | 12:50 PM
blue thunder's Avatar
Crank it over with no plugs in it and see if the noise is still there and if it turns over smooth. It sounds to me like something else let loose.
blue thunder is offline
Old 12-19-2011 | 05:05 PM
When I said the plugs were fine, I meant no physical damage.. There was water in the cylinders. I'm convinced now that the manifolds are fine, but haven't had a chance to check the risers yet. And yes, it has the old style short risers.
Eliminator28 is offline
Old 12-19-2011 | 05:11 PM
Turned it over with the plugs out, and manifolds off, and it makes an ugly thunking noise.
I'm just gonna tuck my tail between my legs and pull the motor out, and tear it down. I'd rather it be right then questionable, besides I got all winter.
Old 12-19-2011 | 06:46 PM
tcelano's Avatar
Stuck exhaust valve?
tcelano is offline
Old 12-19-2011 | 07:15 PM
Horrible feeling. I broke a crank near WOT right after labor day so I can associate well. Good luck and hopefully it won't be too bad in there because it was not under heavy load/rpm. Let us know what you find.
Old 12-19-2011 | 09:28 PM
Thought about that.. But doesn't make sense at idle.. cold water on the stem maybe. I was pretty careful when I built this thing. I put 11/32 stem valves in it and clearanced the exhaust stems to .0018-.0020. There would have to be a lot of movement to stick them.
When I get it apart I'll post up some pics so all you guy's can have some fun at my expense
I'm trying to have a sense of humor....
