Gasoline Quality >
Gasoline Quality
Gasoline Quality
Old 12-24-2011 | 03:19 PM
  #41
There's also a discussion, on the E10 topic on the "Do it Yourself, Boating on a Budget" forum http://www.offshoreonly.com/forums/d...uys-using.html that I have been jumping back and forth to, which you might want to also read. It contains some other thoughts that weren't in this forum.
KachinaShadow is offline
Old 12-27-2011 | 08:13 AM
  #42
Originally Posted by Randy Nielsen
soldier4402, car engines are built on an assembly line & do not suffer the continued abuse of high rpm operation for long lengths of time, Take a car engine (350-454) whatever run it at 4-5000rpm & see how long it lasts, Do the same with an identical boat engine I rest my case.Randy
Ok so the 454BBC is not straight off the production line, its built by little boat elves somewhere
soldier4402 is offline
Old 12-27-2011 | 09:59 AM
  #43
Knot 4 Me's Avatar
Many of Merc's and Volvo's marine engines are based on standard GM long-blocks.
Knot 4 Me is offline
Old 12-27-2011 | 10:56 AM
  #44
Im pretty sure on your standard engines everything is the same minus the cooling system, painting them black to be corrosion resistant and the externals being supposed marine ie starter, alternator, etc.
