Fluid capacity of B/W trans >
Old 06-20-2002 | 02:04 PM
Default Fluid capacity of B/W trans
I know this has been posted before but I need to know what the capacity of the B/W tranny's and if there is a drain plug or do you just vac it out of the dipstick hole, Thanks, Fred
fred is offline
Old 06-20-2002 | 06:25 PM
mfb357's Avatar
Fred, I dont know about the drain plug. I think it would be hard to get to anyway. If the oil is warm I use the small oil suction tube that comes with most oil change kits. then pump it out. There is approximatly 2 quarts in it. I put in 1 and a half quarts of Dextron II then run it in and out of gear then recheck and top off. Good luck, Mark B.
mfb357 is offline
Old 06-21-2002 | 07:27 AM
Thanks for the info Mark, thats what I ended up doing....sucked it out with oil change hose, filled to line, ran in and out of gear and re-checked,....Fred
fred is offline
Old 06-21-2002 | 10:22 PM
Doug's Avatar
(aka) Pure Adrenaline
Dextron II ?? Thats not the same as type F is it.
Doug is offline
Old 06-22-2002 | 08:02 AM
Mbam's Avatar
Offshoreonly Advertiser
Guys, use type F ro FA fluid. Less chance of slippage. Dexron has friction modifiers in it for those nice smooth shifts.
Mbam is offline
Strip Poker 388
15
03-13-2007 07:11 PM
Scarab3DMC
03-25-2006 08:34 AM
cig28
3
04-17-2005 08:31 PM
hystat
2
05-27-2002 05:35 PM
