Best oil in Insta-Trim >
Old 06-20-2002 | 07:21 PM
Default Best oil in Insta-Trim
Any suggestions on what's the best oil to use in Trim Pump. I have the Insta-trim setup.
Much appreaciated
John
Johno is offline
Old 06-21-2002 | 07:27 AM
99Hammer
You can get some insta trim biodegrable stuff from the insta trim site. I just use ATF fluid or trim fluid in mine. Actually sinci I have started to use the trim fluid, some small leaks I have had stopped. Dont fill the cylinder all the way up fill it to about 1/2 way (middle between add and full lines). Just remeber to work the tabs 5-6 times after you refill to get any air out of the lines.
Lynn-X
Baja
13
11-09-2010 07:15 PM
truckone
01-23-2006 12:47 PM
bajaboy2004
1
08-04-2004 05:49 PM
Julio
6
07-10-2003 11:04 AM
WRedmann
6
07-08-2003 08:11 AM
