575sci water pressue gauge mounting... >
Old 03-16-2012 | 12:07 PM
Originally Posted by MILD THUNDER
I think that might be tapped into the runner for boost/vacuum. Could drill the intake at the rear water jacket and 1/8th pipe tap it and install sender fitting there.
BTW your not getting any glass work done I see
did a little last night and I'm sneeking out early today.
kvogt is offline
Old 03-16-2012 | 12:21 PM
Originally Posted by 1 MAIDEN AMERICA
Mine's in the side of the block and has never plugged. At the end of the year I disconnect it to drain the water. Don't go boating in dirt? The yearly unplug probably helps drain sediment out which should be done anyways.
Agreed that this would be an easy way however, my engines are so close together, getting there is very difficult. Besides... I like using power tools lol
teamsynergy is offline
