575sci water pressue gauge mounting... >
Old 03-13-2012 | 11:33 AM
Default 575sci water pressue gauge mounting...
Wondering what the best place is to mount the required fittings to read the water system water pressure. Installing a couple gauges this weekend and wanted to get some ideas. I have installed a few in other boats in the block drain areas but wondering if there is a better location...
teamsynergy is offline
Old 03-13-2012 | 12:16 PM
jbraun2828's Avatar
I'm moving mine to the top of the intake. Hopefully no more cleaning out lines.
jbraun2828 is offline
Old 03-14-2012 | 02:19 AM
sac
I have drilled holes in the block above the block drains so they don't get plugged, or go to the intake manifold.
sac is offline
Old 03-14-2012 | 08:36 AM
I have used the drain plug on oil cooler if you have one. Normally its 1/8th NPT plug. Rotating the cooler a bit helps so sand or whatever doesnt accumulate there. Or you can drill and tap the back of the intake manifold, at the rear water jacket.
MILD THUNDER is offline
Old 03-16-2012 | 09:33 AM
I was think the intake manifold however I am thinking on cutting the hose from the sea water pump feeding the motor, inserting a 2" long piece of stainless, clamping it in place, then in the middle of have a tig welded fitting to attach the tubing to...
Where abouts would I drill and tap in the intake??
Attached Thumbnails 575sci water pressue gauge mounting...-575sci-intake.png
Old 03-16-2012 | 10:10 AM
It looks like there is pipe thread port on each side at the rear water ports. Look in the picture near the distributor hole.
kvogt is offline
Old 03-16-2012 | 10:13 AM
I think that might be tapped into the runner for boost/vacuum. Could drill the intake at the rear water jacket and 1/8th pipe tap it and install sender fitting there.
BTW your not getting any glass work done I see
Old 03-16-2012 | 10:16 AM
I believe teague or cp sells a contraption made of stainless that you are talking about. They make it for a psi relief valve. 1 1/4 slip fittings on each end, with a 1/2NPT pipe fitting (where the psi relief valve would thread into), and you could get a 1/2NPT to 1/8NPT bushing and put it there.
I'd save the dough, and just drill the intake at the rear water jackets. You will get a good reading of what psi is in the block/heads.
Old 03-16-2012 | 11:31 AM
I normally go into the front of the intake. That big flat area just to the side of the thermostat housing would probably work as long as the exhaust water hoses aren't in the way. That's where I would go.
Eddie
Young Performance is offline
Old 03-16-2012 | 11:41 AM
1 MAIDEN AMERICA's Avatar
Mine's in the side of the block and has never plugged. At the end of the year I disconnect it to drain the water. Don't go boating in dirt? The yearly unplug probably helps drain sediment out which should be done anyways.
1 MAIDEN AMERICA is offline
