Wrenches are a flying!! Water in Oil! Help!! >
Old 04-10-2012 | 07:22 PM
  #51
Originally Posted by HiMark Racing
Uhhhh, I put about 20lbs on them..Why don't I want to torque them?? Is that not good??
No good. ARP specifically recommends finger tight. By torquing them into the block, you can put uneven stress on the stud when the heads are torqued. This can lead to a cracked deck on your block, from what I been told.
Like Mike said, apply the sealer to the threads, and assemble everything and torque to spec before the sealer cures. I torque my heads in 3 steps, up to max torque spec.
MILD THUNDER is offline
Old 04-10-2012 | 07:24 PM
  #52
like mild thunder said,hand tight only,if you put torque on it the blockWILL crack at the bolt holes.
mike tkach is offline
Old 04-10-2012 | 07:27 PM
  #53
Great..that took me forever to pull those..can I just loosen them up a bit?? I put "The right stuff" on the threads.
HiMark Racing is offline
Old 04-10-2012 | 07:30 PM
  #54
Uhhhh, I torque them into the block..20 lbs..not good..Why??
Please dont take this the wrong way, but you might want to slow down a bit, and take your time. Do your homework, and assemble it properly from here on out. If you don't know for sure, dont put it together. Wait for someone who does that can steer you in the right direction, whether its here, or on the phone, or in a book.
Old 04-10-2012 | 07:32 PM
  #55
himark,you didn,t say but im guessing you have a gm botie block.pm me and il give you my phone number if you want to.2 of my boats have bowtie blocks.
Old 04-10-2012 | 07:36 PM
  #56
the deep's Avatar
Fast Singles Club
Veteran: National Guard
+1 These guys know their stuff !!! There is a lot more to this than just bolting parts together and the proper way is especially critical with marine engines . Number one rule , do not assume anything . You came to the right place for quality help .
the deep is offline
Old 04-10-2012 | 07:54 PM
  #57
Your so right..I have been doing my homework on everything..I had rain coming today and didn't take the time to read...and just went a head on what I thought was right..I took tomorrow off and and going to pull out all the studs..get a thread chaser and clean it all out and start again..slowly..
Old 04-10-2012 | 07:55 PM
  #58
Yes, it's a Botie Block..pm on the way.
Old 04-11-2012 | 12:48 AM
  #59
The head studs have got to be it..a few were like finger tight and the one's that go into the water jackets that go thru the dowel..looked like coffee residue all over them..I was thinking of having the heads pressure tested and surfaced..but the shop thinks I would be wasting money..and that money is my booze money for Havasu. (Big Booze Budget, Ha!!). There telling me my heads and block are pretty much bullet proof and should be the last thing to look at.
So, I just finished pulling ALL the studs, sealed them and tightened the studs into the block..Gonna let it sit over night and put the heads back on in the morning..need some ARP lube.
Originally Posted by Griff
Do the head bolts go into the water jackets????? They do on some BBC Gen engines and you need to use sealer on the head bolts.
What sealer did you use????? ARP makes a teflon sealer and RTV makes a good high temp thread sealer. I've never had an issue with either one.
Griff is offline
Old 04-11-2012 | 11:15 AM
  #60
737jetmech's Avatar
Do know what the water pressure is inside the chiller @ speed ? I run a pressure gauge on mine with a relief valve . I try to limit pressure @ 12 psi but often see 20 -25 lbs @ speed . The last 1000 rpm as speed increases ... pressure increases from 12 psi to 20-25 psi . I use the drive lwp to feed the intercooler . Were talking ram pressure here ... no pump ... just a thought !
737jetmech is offline
