Wrenches are a flying!! Water in Oil! Help!! >
Old 04-11-2012 | 07:56 PM
  #61
did you use valley gaskets with the intakes ? i made that mistake once.
38tg is offline
Old 04-11-2012 | 09:42 PM
  #62
obnoxus's Avatar
Charter Member #1171
I would run a tap into the bolt holes as well
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 04-11-2012 | 09:56 PM
  #63
Originally Posted by obnoxus
i would run a tap into the bolt holes as well
+1
MILD THUNDER is offline
Old 04-12-2012 | 12:01 PM
  #64
Yup, did that also..
My brain is cooked..Spent a whole day yesterday pulling all the studs..cleaning out threads, sealing..everything done right..filled system with water and pressure tested.. and I still have a LEAK!!! Nothing changed..leaks down just as fast..I hear nothing..see nothing..I left the blower off and valve covers off to see if I see a leak..nothing!! 13 days and counting...
HiMark Racing is offline
Old 04-12-2012 | 02:00 PM
  #65
vette131's Avatar
try pressure testing it with the distributor out & use a borescope or a mirror to look under the intake for a leak.
vette131 is offline
Old 04-12-2012 | 05:08 PM
  #66
We think a like..did that..no leak there..
I pulled the heads off and sent them to shop to get pressure tested.
Old 04-12-2012 | 05:11 PM
  #67
Nope..used "The right stuff". When I pulled the intake off this last time..RTV was pressured equal also on all 4 ports.
Old 04-12-2012 | 08:06 PM
  #68
to bad you live so far away,i have a 1000 hp engine sitting in the shop you could use for havazoo.
mike tkach is offline
Old 04-13-2012 | 11:42 PM
  #69
Update: 3" crack in one of the heads. 12 days till Havasu. Find out Monday if repairable. RHS heads. Less than 30 hrs on them. Never overheated. Not like!!
Old 04-13-2012 | 11:53 PM
  #70
SFOcean's Avatar
Charter Member #394
At least it is not the block; hope it is easily repairable!
SFOcean is offline
