prop question >
prop question
prop question
Old 06-25-2002 | 04:14 PM
bcoffield's Avatar
Registered User
Default prop question
I have 2002 Baja 232 w/ 496 (375hp). Currently @ 26-hours on the engine. The boat came with a Mercury Marine Mirage Plus 23P 3 blade prop and I'm currently getting 67mph (gps) @ 4950rpm with a about 1.5-inches of forward movement left on the throttle. Drive completely trimmed out and just a very little tab, about even with bottom of boat. Manual says max rpm should be 4200 to 4800.
The existing prop is also great for water skiing.
The dealer (BAJA) will give me one chance to swap-out the prop for a bigger prop.
Was looking to try a bigger prop, maybe a 25 or 26 labbed, but was wondering if anybody knows of any place (if any) in the Philadelphia PA area I can go to try different props.
bcoffield is offline
Old 06-26-2002 | 02:00 AM
They gave you ONE chance????? to fix something that they should have had right to start with.
BTW a 25" in the same prop will drop the rpm by about 400 and should do the job for you.
Griff is offline
Old 06-26-2002 | 06:57 AM
Mbam's Avatar
Offshoreonly Advertiser
Try a 23" Revolution, it will drop 300 RPM from where you are at and should be worth a couple of MPH
Mbam is offline
bimmerboy318
Prop Talk
7
07-12-2008 09:46 AM
fountain 47 sc
Drives and Lower Units
1
03-09-2008 07:57 PM
Sea-Dated
Prop Talk
15
06-02-2006 04:49 PM
Excalibur502mag
0
08-12-2004 12:40 AM
FlyFast
1
08-06-2004 10:22 AM
