Gaffrig Muffler air actuator >
Old 04-07-2012 | 08:01 AM
Ran-Dom 32's Avatar
Default Gaffrig Muffler air actuator
can these be rebuilt? or should I just look for replacement? couple of them leak right at the shaft seal, & only keep the muffler closed for a couple minutes
Ran-Dom 32 is offline
Old 04-07-2012 | 08:20 AM
Im sure they can be rebuilt. I also think new ones are available thru mcmaster carr or a place like that.
Never had one apart, but i'd imagine its o-rings or seals in there???
MILD THUNDER is offline
Old 04-07-2012 | 11:02 AM
RMPRam's Avatar
If you give me the closed length of the cylinder and the overall length when the "rod" is extended, I will see if I still have some new air cylinders that will work for you.
Gary Kollofski
612-247-7081
RMPRam is offline
Old 04-07-2012 | 01:25 PM
Ran-Dom 32's Avatar
7" & 8 1/2 open
Old 04-07-2012 | 02:18 PM
RMPRam's Avatar
Here is what I have. They measure 6 3/8" overall closed and they have a 1.5" stroke. I have 5 brand new ones left from when I manufactured marine mufflers and used these Bimba stainless units. They may have a smaller inlet and exhaust port than the ones you have but I have the air fittings for them. $50ea. plus freight, which in your case will probably be $5-6.
I also have several used cylinders, in near new condition, for $30ea.
Gary
Attached Thumbnails Gaffrig Muffler air actuator-bpm-engine-bimba-air-cylinders-015.jpg   Gaffrig Muffler air actuator-bpm-engine-bimba-air-cylinders-017.jpg   Gaffrig Muffler air actuator-bpm-engine-bimba-air-cylinders-016.jpg
RMPRam is offline
Old 04-07-2012 | 03:17 PM
Ran-Dom 32's Avatar
Cool, I'll take a couple used ones, take PayPal?
Old 04-07-2012 | 05:38 PM
RMPRam's Avatar
Yes I will take Pay-Pal. E-mail me your contact info and I will send you 2 used cylinders. [email protected]
Gary
RMPRam is offline
Old 04-07-2012 | 07:14 PM
Rookie's Avatar
Yes they are rebuild-able. I replaced the O-rings in them with my O-rings out of my $5 O-ring kit.
Just screw off the the ends, replace O-rings and put them together with some nice grease.
Rookie is offline
Old 04-08-2012 | 01:05 AM
Default fixx
they come in many sizes,,try here if others dont work for ya!
http://www.clippard.com/cylinders/?g...FUrWKgodxinfZA
FIXX is offline
Old 04-08-2012 | 09:06 AM
Ran-Dom 32's Avatar
pic
