HP 500 valve springs >
Old 06-25-2002 | 07:21 PM
gofastpilot
Smile HP 500 valve springs
I need to replace the valve springs on My 1994 500's.What would be a good reasonably priced spring ,retainer and locks set ?.................Gofast
Old 06-25-2002 | 10:04 PM
Official OSO boat whore
I know that Merc is buying the springs from a aftermarket supplier. Proably crane. Or was it comp? Either way, I believe that you want to use the newer HP500efi spring. This spring helps resolve some of the earlier breakage problems.
Cord is offline
Old 06-26-2002 | 08:18 AM
jbrauer's Avatar
Try the info Scott gave me in this thread!
Good Luck!!
jbrauer is offline
Old 06-26-2002 | 07:41 PM
Scott's Avatar
Charter Member #30
I ended up finding the seat pressure was still too high with the new crane springs I have switched over to Comp Cams. If you need a Part # let me know and I will look it up. This info and recomendation came from my head builder. Scott
I have Steps & Bubbles!
Scott is offline
Old 06-27-2002 | 01:25 PM
gofastpilot
Lightbulb
Scott , I was e-mailing comp-cams about springs and they mentioned part # 924-16 for a spring to use. Does that look like what your head builder would use?...............gofast
fastech69
1
09-26-2005 03:56 PM
dean brown
4
09-24-2005 12:55 AM
smokin' gun
4
05-24-2005 04:51 PM
Summer Heat
2
02-21-2005 04:26 PM
rssteiny
1
10-16-2003 07:52 PM
