K-plane thru-hull fitting removal >
Old 04-29-2012 | 04:50 PM
onesickpantera's Avatar
Default K-plane thru-hull fitting removal
Are the thru-hull fittings for the hydraulic lines pressed in or threaded? I put a little heat to mine and leaned on it pretty good with a pipe wrench and it didn't budge. Don't want to get any more aggressive if it's pressed in.
onesickpantera is offline
Old 04-29-2012 | 04:56 PM
Mine are threaded. Wouldnt be surprised if they are corroded
502ss is offline
Old 04-29-2012 | 06:31 PM
Thanks.
No corossion at all but a chitload of 5200. I'm betting they used it to seal the threads.
I'll heat them up a little more and really lean on them.
Old 04-29-2012 | 06:35 PM
Originally Posted by onesickpantera
Thanks.
Be careful, they may look beefy but remember they are hollow, I can show you what one looks like when it shears in half!!
502ss is offline
Old 04-30-2012 | 05:30 AM
Mbam's Avatar
Offshoreonly Advertiser
Not so much heat the fitting, you need to heat the aluminum around it as best you can and keep the fitting cool as you can.
Mbam is offline
Old 04-30-2012 | 07:23 AM
Exactly why I was afraid to lean on it!
Old 04-30-2012 | 07:24 AM
I use a heat gun to get the plate warm, especially around the fitting, and keep the fitting cool by spraying it with penetrating oil.
