Oil filter bypass >
Oil filter bypass
Oil filter bypass
Old 05-17-2012 | 08:19 AM
Originally Posted by mrfixxall
mike,,i have had great luck with crower cam saver lifters,crower grinds a flat spot on the lower half of the lifter,when it spins it dumps oil on the camshaft..
fixx,i did not know about those,il look into it,thanks for the tip.
mike tkach is offline
Old 05-17-2012 | 08:38 AM
+1. I was just researching these, and they seem like a GOOD idea. Looks like summit has them for just under 100 bucks a set. Rhoads has a similar designed lifter with a groove like the crower cam savers too.
I think you may be pleasantly surprised how they work.
MILD THUNDER is offline
Old 05-17-2012 | 06:47 PM
Default fixx
Crower part #
i use the 66000rx3,this lifter has the heavy cuty spap ring to hold the plunger in instead of a square piece of spring wire..55-58 rockwell hardened..jobber from crower is like 90 bucks
they also have a better lifter,differant material and 63-64 rockwell hardened with mirror polished surface where the cam rides..this one is 66000p3 and jobber is around 182.00
best price is from crower unless joe knows a better place to get them
two names,,one was cam saver and now they call them hi lube lifters..
ps.you will loose about 5-7 psi of oil pressure,,shim the spring in the oil pump with a tiny washer to make up for it..
FIXX is offline
Old 05-17-2012 | 08:28 PM
Crower part #
thanks again.
Old 05-20-2012 | 01:30 PM
oil filter has bypass valve, so some junk will get by and can't guarantee cleaning will remove. every engine company has tried to clean oil coolers every way; hot, cold, forward and backward. acid and ultrasonic, still find particles that have or could killed new engine. cheapest option replace it.
keith2500hd is offline
