Questions about different Bravo's? >
Old 07-01-2002 | 10:16 PM
Fountain38's Avatar
Default Questions about different Bravo's?
I busted my prop shaft and prop housing this weekend on my Eliminator Cat. I have stock bravo's behind my 2000, 500 EFI's.
I am going to have to replace my bravo, lower unit, and have found a 2000-2001 bravo H.P. take off with 14 hours on it. I am aware of the XR's and XZ's but what does the HP mean on the bravo. The guy says he has three takeoffs from a 47 foot fountain that was upgraded with new engines and drives and he says they are Bravo HP????
He wants $2700.00 for one or 5000.00 for two. I would like to upgrade to the XZ or XR's but I don't have $14,000 right now.
Also do all Bravo's have low water pickups or not. I am going to have to install a nose cone to match my other bravo.
Any help appreciated!!!!!!
Fountain38 is offline
Old 07-01-2002 | 10:42 PM
John B's Avatar
Fountain38, I'll sell you my new Bravo HP (heavy duty Gimbal), low water P/U, 1.36 ratio drive for $3200 + freight. Never mounted, in merc box.
John 716 542 5435 days
John B is offline
Old 07-01-2002 | 11:04 PM
Official OSO boat whore
Have you considered any of the xr's in the classifieds section?
Cord is offline
Old 07-01-2002 | 11:12 PM
Fountain38's Avatar
Cord, I have new baby due in Aug. really don't have 10-11,000
dollars right now extra. No maternity insurance. Outta my pocket
Thanks John, ill consider that offer.
Old 07-01-2002 | 11:55 PM
Blackhawkdn
If you broke just the prop shaft and lower housing, you can by replacement for under $2000.00 call IMCO, Teague or Performance Offshore in Florida. The foot is made two ways; low water pick up or mid pick up. HD has nothing to do with pick up location.
Old 07-02-2002 | 09:54 AM
Scott's Avatar
Charter Member #30
why does this conversation look so familiar
I have Steps & Bubbles!
Scott is offline
Old 07-02-2002 | 10:58 AM
Cattitude's Avatar
Default At least get aftermarket shafts!
F38- if nothin else, replace your stock 1" shafts with the same size but better alloy- I think the shafts are available for 3-500?
I bet you could get a used XR or XZ lower (They are the same- only the upper gears are different between the two) or even a used Imco lower for the same kind of coin for the stock HP lower. The HP lowers are pretty reliable- for anything but your application.
Try calling Chris at Sterndrive specialists- tell him I sent you, he took good care of me. 315 676 2979 Good luck- and you're still welcome at Beaver if you decide to.
Cattitude is offline
DareDevil
Swap Shop
1
08-21-2008 07:35 AM
mwdill
Prop Talk
11
08-11-2008 03:57 PM
chromecat
Prop Talk
3
07-10-2007 08:50 PM
NW_Jim
66
01-03-2003 06:03 AM
hot water
09-26-2002 12:27 PM
