Stuttering at idol and black smoke. >
Old 06-15-2012 | 05:17 PM
Default fixx
Originally Posted by 1987pachanga22
Thank you guys for the help!
sounds like to me like the choke is snaping shut,,make sure the choke has power going to it and a good ground..their electric and the coil on the choke may be going bad..it will suck open undereway but will also make the engine die..
FIXX is offline
Old 06-16-2012 | 08:50 AM
Default Carb Change?
Just a recommendation but you may want to just change the carb.
http://www.jegs.com/i/Edelbrock/350/...FSrDtgodvk4F0A
Make it simple with easy carb tuning. Also it's inexpensive and Compatible with "gasohol and blended fuels". Just a stock 502 with a not so high RPM WOT so it should be perfect.
IMO
Mariah212Z is offline
