Yellow stained bottem hull help? >
Old 07-02-2012 | 07:40 AM
Plus 2 for Slimey Grimey
Padraig is offline
Old 07-02-2012 | 09:04 AM
Veteran: Army
Fountain of Youth power one. Spray it on and hose it off. The gel coat will still feel smooth like the rest of the boat. No need to rewax the boat!!
snopro13 is offline
Old 07-02-2012 | 09:41 AM
Lemon Juice, spray on, wait five, hose off ......then rewax
Dd24skater is offline
Old 07-02-2012 | 11:07 AM
FSR. Fiberglass Stain Remover. Blue gel like substance will wipe the yellow right off. Only stuff I've ever had to use.
Trash is offline
Old 07-02-2012 | 11:19 AM
Originally Posted by Downtown42
Star Brite Hull Cleaner worked good for me and is less aggressive to your hull than competitive acid based bottom cleaners. Put it in a spray bottle, hose off any areas around the hull ie: trailer, outdrives, wheels before you apply.
I don't know anything that will prevent the staining except consistent waxing the bottom.
http://www.starbrite.com/productdeta...ull%20Cleaners
x2 thats what I use
jeffswav is offline
Old 07-02-2012 | 01:37 PM
+1 that stuff is amazing
T-RAV is offline
Old 07-03-2012 | 08:00 AM
+1 on Power-one
Thunderstruck27 is offline
Old 07-03-2012 | 11:56 AM
buckknekkid's Avatar
Oxalic Acid, most shops in Fla use it.
buckknekkid is offline
Old 07-03-2012 | 05:16 PM
GO4BROKE's Avatar
Power 1 is the best I have used. Also the best rust stain remover I have ever found.
http://fountainofyouthrestore.com/power1.html
FSR is also good, I think it is oxalic acid in gel form.
[img][/img]
GO4BROKE is offline
Old 07-03-2012 | 05:57 PM
Sno-bowl toilet cleaner...put in a spray bottle, spray on hose off then rewax. It also removes stains from bolts, good stuff and cheap!
jim66 is offline
