SBC new build hp/tq request
I think you will be very happy with your setup and keep us updated on your numbers.
Bob Mardera also spec'd my cam for my 385ci. We figured with dyno headers right under 500hp @ 6000rpms.
It runs excellent and idles @ 650rpms in gear and 800rpms N. Has pushed my Challenger to 80.5 GPS @ 6300rpms.
Here are my specs for comparision....
010 4 bolt SBC, bored .040", 0 decked, line honed,
ESP 4340 3.750 crank, ESP 6" 7/16" H beams, Mahle forged FT's 5cc, C77H bearings, Hines Balanced
Melling Racing #10555 oil pump, Hamburgers 7qt marine pan, full length windage tray.
FluiDamper harmonic balancer,
AFR 190cc heads, 73cc, further ported by Carl McQuillen Racing Engines, Isky 6105 dual valvesprings,
Marine Kinetics "RMbuilder" custom Hyd Roller 234/240 .580/.568 112+4
Morel Retrofit Hyd Roller lifters
Smith Bros .083" wall pushrods
Edelbrock RPM Air Gap port matched to AFR port
Holley HP 750 DP
Lunati Voodoo Widebody 1.5 roller rockers
ported GLM aluminum exhaust manifolds
FastGlass Stainless 22" long DRY risers
Full MSD ignition setup, coil, wires, dist, 6AL,
10.15-1 SCR
8.38-1 DCR
You picked the right guy to spec your cam! Bob is the man!
Holley HP 750 DP
10.15-1 SCR
8.38-1 DCR
Holley HP 750 DP
10.15-1 SCR
8.38-1 DCR
http://www.bobistheoilguy.com/forums...Number=1127935
Ryan & Mr Fx;
Thanks for the input. Changing 88 270hp 350 mag alpha to bravo 1 Dart
build. 5000lb 20* b/rider. Normally cruise @ 28-35gps w/42-44wot. HOPE
to bump that top end up to 60mph for 1/2 - 1mi. burst. Will post pics
from day 1 to completion asap. Thanks again to all who have shown an intrest.
Best regards,
Rory
Best regards,
Rory
Ryan & Mr Fx;
Best regards,
Rory
Best regards,
Rory
Uncle Dave
