SBC new build hp/tq request
Engine assembly complete. Waiting on dyno $$$.
Will ya'll in the know please give me your estimates on what to expect.
Dart SHP 40 over
Eagle forged crank & 6" rods w/esp treatment
srp -16 w/ mahle rings
clevite H
Mellings h/v pump
CUSTOM GRIND
sm.bc 112.1 l/s +4*
6.9 overlap
intake 228.4 .555 lft
exhaust 234 .534 lft
Felpro
AFR 195 w/inconel exhaust
70cc chambers
Air gap rpm
Pro systems 830
All MSD
Fidanza aluminum wheel
EMI thunder w/hp
All ARP fasteners
Hamburgers marine pan
Thanks so much for your input.
Rory
Dart SHP 40 over
clevite H
Mellings h/v pump
CUSTOM GRIND
sm.bc 112.1 l/s +4*
6.9 overlap
Felpro
70cc chambers
Air gap rpm
Pro systems 830
All MSD
EMI thunder w/hp
All ARP fasteners
Rory
sbc build
I don't know. Originally spec'ed @ 9.6 I believe.
Have not spoken to engine assembler in a while.
Health issues on his and my side of family.
Thanks, Rory
Thanks, Rory
I would say 450-475hp tuned in with the dyno headers. It looks like a nice build and the AFR 195's are great heads. I run the older port 190cc on my 385ci. With the wet EMI's 410-425hp.
Why the aluminum flywheel in a marine application? I would stick with stock steel.
Thanks Ryan;
Marine kinetics spec'ed alum.wheel as
well as 57-5800 cam. Getting closer to
replacing 88 270hp 350 mag alpha, w/bravo
sbc build. WHAT A PROJECT !!
Thanks again,
Rory
Thanks again,
Rory
Id guess 440 HP and about 430 Ft lb on auto headers.
About 380 HP in the boat - with a S bend.
Ill be interested to see what RPm the torque starts, and if it stabilizes at 3K( which Im guesing with a Madera cam and an air gap it will.
Are you running a 1" spacer on the air gap?
Should be a nice mill. Good luck!
Uncle Dave
Uncle Dave
