oil pump help >
oil pump help
oil pump help
Old 09-13-2012 | 10:50 AM
tcwcar's Avatar
Joe
Default oil pump help
Can anyone please tell me what oil pumps would be the best to use for the motors I'm building....building gen 6 502's that are now 509's, eagle rods JE pistons, AFR 335 heads, crane 691 cams, and 3.3 Whipples, if any of that stuff madders, I'm using the stock 500 efi oil pans....Thanks joe
tcwcar is offline
Old 09-13-2012 | 11:47 AM
tcwcar's Avatar
Joe
Did the the search, what i guess i should have done first....sound like everyone is using the 10778c pump????
tcwcar is offline
Old 09-13-2012 | 12:51 PM
Cobra100+ is offline
Old 09-13-2012 | 12:54 PM
Panther's Avatar
Frank's Marine Service
That's what I have in mine.
Seems like a good sized cam too!
Panther is offline
Old 09-13-2012 | 01:17 PM
Many are running the 10778 high volume pump or the 10778c pump with the anti-cavitation grooves. This pump does have the billet gears and the shaft that extends thru the cover for extra support. FWIW, Bob Madera (AKA RMBuilder) of Marine Kinetics recommended the 10777 pump to me, which is a standard volume pump that I think has the same durability improvements of the 10778 and 10778c pumps. You will get some recommendations against running extremely high pressures and volumes, and apparently Bob is in that camp as well. Perhaps Bob would like to chime in and offer his thoughts on it before I put words in his mouth.
Budman II is offline
Old 09-13-2012 | 01:20 PM
tcwcar's Avatar
Joe
Thanks everyone so far for the info....
tcwcar is offline
