Tunnel Ram & 2 4's >
Tunnel Ram & 2 4's
Tunnel Ram & 2 4's
Old 11-06-2017 | 06:23 PM
Ran-Dom 32's Avatar
Thanks, MT that's the sort of info I was searching for
Ran-Dom 32 is offline
Old 11-06-2017 | 06:43 PM
Tinkerer's Avatar
Mild Thunder - how do I get my hands on one of these Tr's from Wilson and can they be modified for sequential port EFI?
Do I just call them and give them my engine spec's?
Tinkerer is offline
Old 11-06-2017 | 07:02 PM
Edelbrock makes the Victor Tunnel Ram, with injector bungs, with open top plate.
Intake Manifolds - Chevy - Big-Block - Victor Series - Edelbrock, LLC.
Theres also the Pro-Flo XT intake, which I think is bad ass. Not really a traditional tunnel ram setup , but really cool imo. I think it be a nice top end for a EFI-540-565 build, rather than some lamo single plane with a throttle body on top. Seen enough of those already
Intake Manifolds - Chevy - Small-Block - Pro-Flo XT Series - Edelbrock, LLC.
MILD THUNDER is offline
Old 11-06-2017 | 11:13 PM
Would be interesting to see that back to back vs MPI and merc racing efi manifolds. Send one to articfriends?
hogie roll is offline
Old 11-07-2017 | 07:31 AM
Some good info here. They had a 540ci, 8.8:1 compression, 271/280 .742/.715 lift cam , Dart 355 cnc heads.
Weiand Team G single plane with dominator = 770HP/663 TQ
Weiand Tunnel Ram, twin 950 carbs = 777HP/681 TQ
Dart Tunnel Ram Twin Dominators= 806HP/694 TQ
Dart Tunnel Ram ported by Wilson = 833HP/712 TQ
The Wilson ported combo is up a solid 50hp at 6000ish rpm, and 30-40ftlbs thruout the midrange. Doesnt look like it gives up anything anywhere to the single plane setup.
160 additional HP from only an induction system change is impressive. Period.
payuppsucker is offline
Old 11-07-2017 | 07:51 AM
Supercharge it and be done!
Warship2k15 is offline
Old 11-07-2017 | 10:13 AM
i know you are old like i am but recheck your math!
mike tkach is offline
Old 11-07-2017 | 10:17 AM
Guess I should've waited until I had my coffee.
Old 11-07-2017 | 10:53 PM
Add in some Elijah Craig or Makers to that coffee
endeavor1 is offline
Old 11-09-2017 | 03:23 PM
I was looking into the option of going to a tunnel ram setup with EFI on my big inch NA motors. I don't think you could realisticly have a better induction setup. The long intake runners of the tunnel ram with fuel curve adjustability of the EFI. I wanted to go to a little different cam profile to try to take advantage of the induction setup then see what the dyno had to say about my idea but found a set of 10-71's I just couldn't pass up. Going with carbs on top for now but eventually I would like to go to an EFI setup on the blowers too. We'll see how things go.
dandercam1 is offline
