View Poll Results: 114 or 112 for low rpm power
114
15
45.45%
112
18
54.55%
Voters: 33. You may not vote on this poll
Cam LSA
Old 12-04-2012 | 09:48 PM
  #71
Originally Posted by GPM
I run mine there
im just curious,what do you run at 7500 rpm?
mike tkach is offline
Old 12-04-2012 | 10:03 PM
  #72
GPM
Procharged 598, it's not something I do every day.
GPM is offline
Old 12-04-2012 | 10:24 PM
  #73
sorry,i ment what engine do you run at 7500 rpm?
Old 12-04-2012 | 10:31 PM
  #74
148
What engine setup?
MILD THUNDER is offline
Old 12-05-2012 | 01:27 AM
  #75
Default fixx
Originally Posted by MILD THUNDER
I didnt do the actual test. Not sure who did. But even when you plug the numbers, low static compression combined with a late closing intake valve, with his stroke and rod length, it comes out to 120psi cranking.
This calculator is pretty close. My calculated numbers on my engines, and what they actually show on the gauge, is within about 5psi.
http://www.wallaceracing.com/dynamic-cr.php
gotcha,,thanx for the link!
this is what it said mine is(600sc) and 7.5 ~1
Static compression ratio of 7.75:1.
Effective stroke is 4.00 inches.
Your dynamic compression ratio is 7.35:1 .
Your dynamic cranking pressure is 142.35 PSI.
Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 5 PSI is 9.85 :1.
V/P (Volume to Pressure Index) is 214
FIXX is offline
Old 12-05-2012 | 06:01 AM
  #76
Neat. Heres mine. Using 600FT above sea level for altitude.
Static compression ratio of 8.8:1.
Effective stroke is 3.52 inches.
Your dynamic compression ratio is 7.74:1 .
Your dynamic cranking pressure is 152.29 PSI.
Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 6 PSI is 10.90 :1.
V/P (Volume to Pressure Index) is 188
