Any Ideas??  4 QTS oil sprayed in bay!! >
Old 07-18-2002 | 09:38 AM
blown formula's Avatar
One of the first things I checked was the external oil feed & return lines on the 'Chargers. Also, the 'Charger is mounted on the port side & had no oil on it. Much disassemby is required for access DOWN into the engine bay & that is what I will be doing this weekend. Compression/leak down is one of the primary tests I will be doing.....although the engine does run smoothly with no load, I will try it again under load before tear down, just as a test.
blown formula is offline
Old 07-18-2002 | 05:25 PM
Mr Gadgets's Avatar
Charter Member #601
blown formula,
I wouldnt pull it all apart just yet.. you may end up not finding anything..
At what speed are u running at 3000 rpm's? Is it possible to open the hatch some and have someone looking into the engine compartment? If you have electric hatch lift, you may be able to do it..
Disclaimer.. Kids dont do this at Home!!!
That would save you a bunch of work.. if you can see the source then pull it apart.. If that is not a doable deal.. pull the hatch and watch.. what happens.. well have a friend watch.. YOu know what I mean..
Good luck!! and let us know what u find.
Dick
Mr Gadgets is offline
Old 07-18-2002 | 05:40 PM
3000 is about 45mph. pretty difficult to have tha hatch open!!
I am going to do a lot of exploring before i tear it down.
Thanks guys....
Old 07-19-2002 | 11:07 AM
Mr gadgets-
When I said"tear it down", I really did not mean tear the engine down. I was speaking of removing all the supercharger breathing tubes and filters and other accessories in order to gain access DOWN into the engine bay. A Formula 312 is pretty tight in the engine room anyway without Prochargers. With them, don't ever drop a tool....it's gone!! I have a couple under that port engine now!! Even if this thing never leaked another drop, I would still need to clean up the mess from this time. DOUBLE YUCK!! I can't stand that kind of mess!!
Old 07-19-2002 | 01:12 PM
jspeeddemon's Avatar
Like someone said earlier, remove the hatch and take it for a ride. Have a friend look over the back seat, I'll guarantee you will track it down. Heck my buddy never puts his engine cover on his Blown Scarab, has ridden it like that for two years.
jspeeddemon is offline
Old 07-20-2002 | 12:42 PM
BajaBoss252's Avatar
I sure would like to have that air conditioned garage big enough for my boat you spoke of
BajaBoss252 is offline
Nordicflame
10
09-07-2025 10:48 AM
John B
22
05-13-2008 03:25 PM
REBEL4845
4
05-27-2005 05:26 PM
Danny_Ocean
7
04-11-2004 11:41 PM
blown formula
8
07-23-2002 07:57 PM
