Alternatives to Procharger intercooler >
Old 07-31-2013 | 05:12 PM
Default Btw
you want the intercooler that reads 150 psi,,,these coolers are alot thicker so they wont rot out as fast and may last alot longer..i have a ? do you have a pressure relief valve? you may have too much water pressure and may be blowing holes in the coolers
FIXX is offline
Old 07-31-2013 | 05:33 PM
Turbojack's Avatar
Check out Rtech,
When installed on a boat in exchange of the stock intercooler they were getting more HP. When I put one on my boat with a m4 procharger the FAST ecm & O2 sensors required 15% more fuel, due to the cooler intake charge and increased air flow. Do not know how much HP increase I got but with using 15% more fuel had to be a pretty good increases with only changing the intercooler.
Turbojack is offline
Old 07-31-2013 | 10:35 PM
bck's Avatar
bck
Charter Member#568
Find tomcat here on the forum or his company R Tech. Hopefully he's still in business, he's got all the intercooler stuff figured out.
Straight bottoms and flat decks
bck is offline
Old 08-01-2013 | 07:34 PM
mcollinstn's Avatar
I'm getting quotes on finned cupronickel tubing. It's a straightforward job of cutting open the Procharger coolers and fabbing up a CuNi zigzag cooler circuit in them. The finned tubing is expensive, and the box to tube seal is tricky but otherwise no magic.
MC
mcollinstn is offline
Old 08-02-2013 | 03:57 AM
Frozen Boost type 22. Done.
Griswald is offline
