First start up on my new big block :) >
Old 07-15-2013 | 10:25 PM
Originally Posted by Sydwayz
Sounds good, but you need to trim that outdrive down to neutral or just slightly above neutral; or you are going to be pulling it all apart again to replace the U-joints or worse on your Bravo. That's why trimmed all the way up is called the "trailer position."
With a Bravo setup; the drive shaft is spinning as soon as your start the motor. The "clutch" and "shift" mechanism are in the top of the drive. You are putting a terrible bind on your U-joints; NOT good at all.
When are you installing the hydraulic steering?
Thanks for the tip, its not at full trailer. But i can see exactly what your talking about! And really appreciate the tip! I'm just looking at the different systems now. I do wish to go dual ram. Any suggestions?
Mtuned is offline
Old 07-15-2013 | 10:26 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
IMCO would be my first choice since Marine Machine is now semi-retired.
Sydwayz is offline
Old 07-15-2013 | 10:40 PM
http://www.cpperformance.com/p-13898...rn-drives.aspx
How would this system do?
Mtuned is offline
Old 07-16-2013 | 01:01 AM
Make sure to go with dual ram full hydraulic to the helm and not just an add on system.
Griff is offline
Old 07-16-2013 | 05:09 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Originally Posted by Mtuned
Ideal.
Sydwayz is offline
Old 07-16-2013 | 07:49 AM
Congrats on getting your new engine done. I got mine done a couple months ago and its a great feeling. Now that I have the drive fixed we are back to running it. What prop are you running? 70 at 3000 is fast. I have bad slip at 3000-3800. I only get about 50-55 at 3500 with a 32p bravo. It really starts to hook up about 4000 and up.
cp5899 is offline
Old 07-16-2013 | 08:16 AM
I think i have the link to my prop in the first post. Its a hydromotive 30P I get high slip at 3000 if im nose down. Once i trim nose up it slingshots. Every haul is very different
Mtuned is offline
Old 07-16-2013 | 08:40 AM
What is the difference between the two in terms of safety? Or is the full helm just nicer drive? Big price difference so just asking
Mtuned is offline
Old 07-16-2013 | 08:47 AM
70mph/3000rpm/30p/assume 1.5 = -23% slip?
1.36=-12%
how much sugar is in that koolaid? just sayin...
Griswald is offline
Old 07-16-2013 | 12:15 PM
You are 200% correct, very sorry it was 4000 rpm. Was not trying to pull one over on anyone. Just honest mistake
Mtuned is offline
