Engine Oil Questions. What do you think i the best!
Oil is like peoples children they think theres is the best. Key is to use and change it, and ensure it meet specs and use the proper weight, IF your on stock engines youll be fine.
You should go buy the cheapest oil you can get, fill her up, start it, go for one light run, and drain it. If you had fuel in the oil it needs to be changed at least once additional. Then buy the expensive oil and run it.
Mobil1 racing oil 0-30 / 0-50 see bottom of page 2.http://www.mobiloil.com/USA-English/...duct_Guide.pdf.
My opinion on the V TWIN oil is, its designed for wet clutches in a motorcycle not a car,truck,or boat unless it has a wet clutch in it.
Why do oil threads refuse to die
? The OP already decided on Mobil 1 15w-50 which, IMO, is as good a choice as any! Soldier, you should be changing that oil at winterizing time and run it through the motor. Not in the spring. Oh. oh. I just threw fuel on the fire.
Amsoil is indeed good oil. I run the Mobil because it is readily available at any auto parts store.
Mobil 1™ VTwin
20W-50 1600 1750
Advanced full synthetic formulas
designed specifically for
motorcycles where clutch
lubrication is also important.
All motorcycles where
20W-50 is specified,
especially V-Twin
engines SJ
Mobil v- twin oil is a very good oil withstanding very high temps while combating oxidation from high moisture. Works good in my 621 15:1 comp drag car aswell. Also can never go wrong with Gibbs hot rod oil. Both will be priced from 9 to 10 bucks/ quart. The Gibbs hot rod oil is also recommended for v-twin applications ironically enough. Just because a product can have more than one use (in this case high temp/pressure environment which furthermore proves it's durability) doesn't mean it will not work...not at all. Research, research....-Chris
Gibbs makes a great product too, but again not readily available which is most important to me.
