496 replacement injectors >
Old 07-29-2013 | 04:45 PM
rvtransport's Avatar
Default 496 replacement injectors
Does any one know if there are other options for injectors on 06 496hos. Mercury PN 881693002. Dealer wants 214 dollars each!
rvtransport is offline
Old 07-29-2013 | 05:59 PM
The Merc 496 is a GM Vortec 8.1L. A Lot of parts are interchangeable. You should be able to find them at the local parts store. Here is a link to rockauto.com they are $52.00 http://www.rockauto.com/catalog/more...206&cc=1432495
low_psi is offline
Old 07-29-2013 | 06:03 PM
Rock Auto sells reman injectors for marine motors, http://www.rockauto.com/catalog/more...34&cc=10001436 They are $62.00 each and have a $35 core. But I don't think there is a difference between the Delco injectors and what is being sold as "marine" parts for this motor..
low_psi is offline
Old 07-29-2013 | 06:14 PM
Found a post from Raylar from a while back that stated the Marine Injectors are different.. So scratch my first post. But my second post looks like a way to save a large chunk of $$. Even if you buy them without exchanging your old ones, you stand to save $117 per injector. Have you considered sending them out to a fuel injector service company? I have plans to send mine out in the off season. They test, clean, replace O-rings, change screens and dyno your current injectors. If bad, they can repair. I think I remember getting a quote of $25 or so per injector. A lot of Diesel and turbo specialists handle injector service, or will know where to send you.
low_psi is offline
Old 07-30-2013 | 10:03 AM
Thanks for info!
