Should there be oil on spark plug threads? >
Old 08-06-2002 | 06:58 PM
ttt
Pure Energy is offline
Old 08-07-2002 | 10:35 PM
A friend suggested bad valve guides. Could this be the/part of the problem?
Old 08-07-2002 | 11:59 PM
The oil sheen could be fuel. Dont be freaked out . Get the float level checked then the power valves, too much fuel pressure, etc,and monitor the vacuum readings at each 500 rpm. Record what you have and keep digging. The oil pressure will drop when the oil is hot. A straight weight (40 or 50)might be a good choice. Probably the carb. Greg
HPJunkie is offline
Old 08-08-2002 | 05:14 PM
Tantrum's Avatar
Question
A valve guide problem ???
What is the logic behind it ? Did you have valve work done ?
This is a real question, not sarcastic, my smiles are not working.
Actually my smillies stopped working the same weekend my motor took a $h!% which appears to be valve related
Tantrum is offline
Old 08-08-2002 | 06:06 PM
My brother in law suggested it. He is a mechanic. Yes, I had a "competition" valve job done and new inconel exhaust valves. I guess just something else to ponder.
Old 08-09-2002 | 02:39 PM
Tantrum's Avatar
Why yes......
That is ponderous
Im going up to the Cape this weekend and bringing my BICYCLE!
Atleast if anything in the motor breaks you just have to cast it for 6-8wks and BAM your good as new.
Tantrum is offline
bleachers
Do It Yourself, Boating on a Budget
3
07-25-2008 09:59 AM
SSComp
1
07-14-2004 01:17 PM
RebarBox
05-31-2003 08:39 PM
252 Baja
Baja
4
07-14-2002 11:52 AM
29Fever
13
05-05-2002 01:05 PM
