IMCO or Sportsmaster Lower? >
Old 01-13-2014 | 09:47 PM
Default IMCO or Sportsmaster Lower?
Is this an IMCO or a Sportsmaster Lower. Its 9.25" from the top where the lower bolts to the upper to the center of the prop shaft. The prop shaft is 1" and the input shaft is 1.25". Can't see any identifying markings on it.
ealesh33 is offline
Old 01-13-2014 | 11:17 PM
Looks like an Imco to me. Should have a mark stamped in the housing -0, -1 or -2. Meaning standard length, 1" shorter or 2" shorter. The stamping would be forward of the vertical shaft, right at the front point of the drive on the horizontal flat surface. In the 3rd picture it would be on the right,under the dirt at the point of the drive.
Revd Up is offline
Old 01-13-2014 | 11:31 PM
Here's mine. Yours looks the same, except it appears to be 1 or 2" shorter.
Revd Up is offline
Old 01-14-2014 | 12:06 AM
You have an excessive amount of shiny things sir..
Drock78 is offline
Old 01-14-2014 | 01:48 AM
Imco
Griff is offline
Old 01-14-2014 | 04:33 AM
Originally Posted by Griff
Imco
Agree
Rattlesnake Jake is offline
Old 01-14-2014 | 06:19 AM
Thanks for posting this for me Eddie. Whats it worth If it is an imco? As-is....Operates fine without any noises, not sure of hours or last time it was gone over. Ill check for the stamps tonight to try and be sure it is an imco.
pwrboatn is offline
Old 01-14-2014 | 06:31 AM
2K? You can buy them new from Diamond for 4290. 1" prop shaft is a hard sell.
Old 01-14-2014 | 06:33 AM
Okk sounds good i have a guy buying it for 1600 tomorrow night just wanted to make sure neither of us were getting ripped off. Thanks guys..
pwrboatn is offline
Old 01-14-2014 | 06:54 AM
Look for the stamp for sure, might be worth more to someone if it is a -2.
Baja226sport is offline
