Cam shaft numbers >
Cam shaft numbers
Cam shaft numbers
Old 01-30-2014 | 04:50 PM
  #161
and why did you promise Adam a 731, and not give him a 731, but a cam that was "close".? Once again you say you are gonna do one thing, which is pretty simple, and can't even do that right.
Even though it was not what you promised, you gave it free. Why would you give away something free, if that was not your claimed cause of the problem?
Zone 5 is offline
Old 01-30-2014 | 04:51 PM
  #162
Originally Posted by cstraub
540 Had EMI Thunders
Just so you know the next time, those are not stock Merc exhaust
Zone 5 is offline
Old 01-30-2014 | 04:53 PM
  #163
Overlap 76
I was used by several with wet exhaust.
At what degree was it 76?
Zone 5 is offline
Old 01-30-2014 | 04:59 PM
  #164
SB
Ding, ding, ding, ding. We have a winner.
You'd think he'd learn this by now.
I don't know if you saw this some years back, but he cammed a set of engine's with dry (to the very end of the tailpipe tips - as they normally are) Stellings, and they reverted. Yup, who would think that was possible ? But, he did it. And yes, I got pulled into that fiasco to to help.
SB is offline
Old 01-30-2014 | 05:19 PM
  #165
rmbuilder's Avatar
MarineKinetics
NOBODY has control over what happens with used wet exhaust. That cam has since been run in another marine engine and is still running today..
That is the most blatantly inaccurate remark on this entire thread. On every engine we consider multiple compound variables, including bi-directional wave motion and pressure excursions, from the intake tract to the atmospheric end of the exhaust tract, that factor into the propensity toward water ingestion. Then you recognize and mitigate the factors you can alter, adjust the valve events accordingly, while building a margin of safety. Only then can you proceed with generating a valve path.
At that juncture you consult with the client, advising them that the components they will be utilizing (if they are prone to supporting reversion) will detract from the targeted specific output by a factor of X. That provides the end user with two valuable tools, accurate information and the opportunity to make an informed decision. There is every opportunity to exert “control over what happens with used wet exhaust. “
Bob
rmbuilder is offline
Old 01-30-2014 | 06:43 PM
  #166
I believe cstraub is at the Library thumbing through a Dictionary and a Thesaurus franticly trying to figure out what Bob just said!!
abones is offline
Old 01-30-2014 | 06:49 PM
  #167
I just put a Rosetta Stone tape in my cassette player to try and translate his post into words I can understand! Lmao. Just kidding Bob, good post, glad you chimed in.
MILD THUNDER is offline
Old 01-30-2014 | 07:36 PM
  #168
and not surprisingly he is absent from this thread.
Zone 5 is offline
Old 01-30-2014 | 08:20 PM
  #169
Soo I just want to chime in . Mike told me about the 731 cam and he got kinda crucified but I'm seeing I guess that it is a good off the shelf cam?? While everyone's fired up here I'm just curious what is the best centerline to go with on a cam to not have reversion? And since you guys have built engines should I do my 502 block to 540 or just get a dart. I will be running about 5-7 pounds of boost and now that my butt stopped hurting from buying the crank ,rods and pistons I want it to be ok.......
Eliminatorshane is offline
Old 01-30-2014 | 08:27 PM
  #170
Soo, you bought a 502 rotator and just got over the cost but you're wondering about going to 540?
HaxbySpeed is offline
